lol.... Now come on Guilt toy....... Dont be too harsh.......
I see it as, If all you want to do is control coils and injectors, then they are not to bad at that.
But as soon as you want to do ANYTHING else.... umm sorry, Like have a timing table that is more than a single line over load/rpm, or a fuel correction that isnt temp related, or control boost......... over wheel speed..... and airtemp..... and tps, Individual cylinder correction, wideband 02 feedback, stepper motor control, telemetry, lambda warnings, oil pressure/ temp warnings, automatic transmission control, oil cooler fan control, PWM nos control......... Wiper speed over wheel speed...... and yes it has been asked for.
I love on ones that say....... O no I cant afford a $2000 ecu so I bought an LTX12, O and here is my $800 boost controller.
Such a shame.
Sorry, im getting lost in my own dribble here........But back on topic. Download the book from the microtech site and read it. Then read it again and it will probably still make no sense.
Have a play with the tune on you ECU for a while, work out what does what....... Then read the book again....... twice......
Set your fueling so your EGT's aren't too high, don't let your engine ping and road tune until your fingers are sore.
When the tune is done and you are happy with your results, put your feet up, grab a well earned frosty one and read a good book.......The Microtech one.
Microtechs are not that bad if you font want all the above features I run one with mo problems at all I have launch control( 2 step) air temp ignition timing and fuel which is all I really need for street if I was doing track work I'd prob use something different
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
