Define stock??
Exhaust cam gears and power fc and a little more boost I saw a gain of 57kw at the wheels 203 to 260awkw and good fuel economy surprisingly
Cost wise:
Cam gears-$200-400
Power fc -$800-1400
Tune-$600-1200+ depending on tuner
Exhaust something over 3inch cost varies
Oh and search next time and look at the rb26 dyno thread
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6156338
Full exhaust 3.5inch after cat, cam gears as above then a nistune ($1100 supplied fitted and tuned)
Oh and a boost controller to up the boost to a max of 12psi
Agreed, except boost, 12psi is stock on a GTR, pull out the restrictor and you get 15psi, a good boost controller will help boost come on a bit sooner by not letting the waste gate "creep" open.
I use 15psi everyday driving/track events and 19psi for drags and dyno with no problems on stock turbos
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6156402
IIts got a 3 inch exhaust and pod filters. I haven't even driven her yet as I bought it while on swing. I'm really just wondering how much can be done.with a tune and maybe restrictor removed if its not already
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6162533
Tune can gears and restricter removed you will be able to get 240+awkw on the std turbos, depending on the tuner
I wielded 260awkw with std turbos, exhaust, 14psi, cam gears and power fc tune
Have a look at the RB26 dyno result thread, top of this page, to see different set up results
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6162964
JJust bought a set of adjustable cam gears from an Australian company called ozsome motorsports they SEEM to be.very similar to tomei you can pick like 10 colours they only.cost 90 bucks direct from the manufacturer with free postage. I'm going to take them into a garage when I get them to get an opinion if they think its ok ill see how it goes. if anybody wants feedback pm me
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6164439
Throw away the fasteners that come with them, and go get some quality fasteners (hi-tensile etc) to use with them
Cheers have you heard of or used these before?any comments? The fasteners are they the bolts to the cam or the adjusters?
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6164475
Adjusters, they tend to come with cheap fasteners. If/when they let go the cam gear will be set to the extreme advance or retard position which is guaranteed to smash at least 12 valves into pistons, 24 if unlucky.
https://www.sau.com.au/forums/topic/385974-gtr-tune/#findComment-6164492
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
