Hey everyone!
My R33 GTS-T S2 has been having a coil pack problem lately :(
For some reason it keeps blowing one coil pack, which is coil pack number 4 - the one that sits directly under the crossover pipe.
I have spare original coil packs and when I replace it drives perfect for about 10 minutes then it starts to misfire again!?!?
Does anyone here know what could be causing this?
Would really appreciate any sort of help :)
https://www.sau.com.au/forums/topic/386194-need-help-with-coil-pack-problem/
Oil? Is the coilpack insulator degraded? Any loose conductive objects around?
A way to test is to run the car at night or in a dark garage, have a look at the coil packs and see if you can see it earthing out.
What do you mean by oil?
Coilpack insulator is fine, no loose conductive objects anywhere. I have removed the spark valley cover but I doubt that has anything to do with the problem.
What do you see if the coilpack is earthing out?
Thanks heaps :)
Whoops, I must have been half asleep when I wrote that post.
Check to see if there is any oil around the coil packs, either from a bad cam cover gasket or something else. If there is oil, or even water it can cause the spark to jump away from the plug.
You'll see sparks from the coils earthing out to what ever they are earthing too. It is a common problem with coilpacks.
I've cleaned up the area around the coil pack/spark plug as much as I can.
There's no sparks as far as I can see but then again I'm not sure where exactly I'm supposed to be looking.
Problem still persists :( not sure what else it could be?
I'll give anyone $60 if they can help me fix the problem? not much but I'm a poor student. Can bring my car to you.
Where else would be ideal to take the car to that won't break my bank?
What's the condition of the spark plug underneath that coil pack?
It's a 2 month old platinum plug.
Try wrapping them in electrical tape?
I had a read of ones which showed signs of slight cracks in them and wrapping in tape helped with the misfire.
A long shot but hey if it saves you money why not
The coil packs have already been sealed with that high-temp silicone stuff.
Thinking out loud.
1. Swap coilpacks and loom over with another 33 to test and If thats the issue
2. Bite the bullet and buy new Splitfire coilpack. If not then nothing spent nothing gained.
Then you can rule that out and move on throuogh the process of elimination.
Woops sorry - you say you keep blowing the same coil pack #4.
They obviously run 12v. Perhaps it's just your loom. Maybe it is best then to replace it all. The first test will identify this.
You say The coil packs have already been sealed with that high-temp silicone stuff.
Well that would indicate it's had an issue!
Thinking out loud.
The silicone around the coilpacks doesn't explain why they work for 5 mins then fail. I have been thinking of buying splitfires but I have a strong feeling that it might do the same thing.
Fouled plugs can cause coils to overheat and die
Swap the plug for another and see if it misses on the different cylinder
I'll try this :)
Is it really worth spending $100 on something that might not even be the problem?
Why would 2 month old platinum plugs be fouled? Especially 1 of 6. If thats is the case then you have another more expensive problem.
I wouldn't just buy a loom for the sake of it - "Swap coilpacks and loom over with another 33 to test and see If thats the issue"
You say that number 4 fails after coil pack has been replaced.Why couldnt it be the loom then.
The point of mentioning the silicon is that either you or the previous owner had a problem. The 5 minute timeframe before it happens could be contributed to heat generated by running for that period of time and the expansion that will occur.
Anywho - all just theory from me.
Yeah I'm fairly sure it isn't the spark plug that's causing the coil packs to fail.
I'll take your advice and go buy a loom tomorrow and see if that will work (found a local one).
Can't be a bad coil pack problem as they do work fine when I try them in all the other cylinders.
So have you swapped the coil pack loom out.
Also have a look in the I can lend you thread if you need more stock coilpacks.
Swapped the coil pack loom today with a $50 one from JapSpec, problem seems to be fixed!
Thanks heaps for helping everyone :)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
