Hey guys i own a r32 gtr 93 model and im having issues with my car.
Il state the mods to help you guys with answers.
Full exhaust system 3 inch
Apexi pod filters
Nismo afm's
Sard 700 cc injectors
Bosch 040 pump
Hks 2530 turbos
Greddy boost controller 15 psi boost
Power fc ecu tuned
Splitfire coilpacks
Iriway 7 spark plugs
The coilpacks were purchased second hand of a member on the forum about 7 months ago, they were fine till the last couple of days as to my knowledge. Now as i drive normal everything is sweet but as soon as it gets past about 4000rpm it missfires then it drops a cylinder and sounds like a wrx. Im guessing its the coilpacks that are efffd, but my car isnt that heavily moded to fail a splitfire coilpack (280 kw at all fours).
Am i right to lean towards faulty coilpacks? Or is it not possible for them to die so easily?
Thanks in advance
https://www.sau.com.au/forums/topic/386235-coilpacks-r32-gtrplease-help/
Sorry don't know the exact name for it but could be the brain that the coil packs are all connected to as well? It kinda dies in the ass sometimes due to heat, but it quite possibly could be the packs themselves. Try another set.
The coils sound dead but try the resitor first it's the silver and black box that sits on top of the coil pack cover. I have coil packs and a resistor you can try to find out the problem I'm on the coast where in syd you live?
The "resistor" box is not a resistor. It's the ignitor. R32 (RB20 and RB26) and S1 R33 RB25 use the same igniter and coils. S2 RB25 coils are not compatible with the earlier ones.
Because all your ignition gear is relatively new, it would be strange (but possible) for something in there to have died. I'd also suspect that one of the injectors might have an issue, so if you get desperate get them tested too.
And then there's the CAS.
cheers
  • 5 weeks later...
i have this same problem i hav new coilpacks and aftermarket ems ignitors and the ems ecu. i hav replaced all these and havent fixed it. i actually burnt out the coil on #3 cyl. i am having the ignitor and coilpack harness replaced to try and fix the problem.
Turned out my ignitor was gone. No issues after replacing with another.
Cheers for the help guys!
Interesting. My brother-in-law was recently handballed a Legnum wagon that no-one else could make work. He worked out that the ignitor was stuffed......but a new one didn't help. Then they found that the ECU was torched. It had had coolant in it at some earlier stage when a heater hose had died. When the ECU went, it took out the ignitor. Sounds like you might have suffered something similar (ie, ECU killing the ignitor).
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
