pitty those shocks are not really a "racing" style. i find the valving is nowhere. we had a customer with them in his r32.
pulled them out and put in his old tien superstreets and was 4 sec quicker at eastern creek... dont need the rain on your parade, but if you have the oportunity to swap them for the normal bc's id advise it.
sorry still in the newb stage here, but you guys havent had any problems using the bc br's in dailys, i was looking at getting them for my r34 in the 8/6 combo but after driving a friends silvia was wondering wether they'd be bone jarringly stiff like his were. thanks
im looking into getting aset in the next few weeks for my r32 gtr
but will most proberbly go with 6-4kg spring rates and then use the damper adjustment to fine tune them
i think the 8-6kg for sydney roads will be way too stiff...
I've got a set of 8/6 (v1's) on a 4dr 33 as a daily car, they aren't that bone jaring (and I drive about 45-50 mins ea way to work and back) on some of the shittiest roads Brisbane has to offer :).- sometimes have to dodge some of the larger bumps or potholes. I've got them adjusted to about 8 clicks off the softest setting
  • 6 months later...
i got BC BR 's 32 gtst 8/6 combo and i find it to hard/harsh even on lowest damper settings. car is used for daily but gets driven hard at times.
i found it better with 2 up to 6 from softest dampening, so as not to be bouncing from bump to bump and i agree with harder on the front than the rear eg 4/3 on the dampners.
i have had these for around 1 year and i think with the softer springs will be one of the ultimate CHEAPER street setups.
i have put the 6kg rear springs to the front and am waiting for 5kg rear spring to arrive.
i was told they would not fit, but can CONFIRM they fit, only difference is the spring length by around 12mm longer in the rear springs.
i just wound down the bottom spring platforms as you would do normally.
i had shagged stock shocks on king lowed springs and locked at replacing shocks and found to be move affordable and performance buying bc racing coilovers, and after being defected with lowered king springs i wanted the height adjustable, so i could get it closer to legal . :)
from mij
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
