Got this in an email today, check it out
They run 10 mph, jump  three feet, are a nocturnal spider, so they only come out at  night unless they are in shade. When they bite you, you are injected with Novocaine so you go numb instantly. You  don't even know you are bitten when you are sleeping,  so you wake up with part of your leg or arm  missing  because it has been gnawing on it all night long.
If you are walking  around and you bump something that is casting a shadow over it, and the sun makes contact with it, you better run. It  will instantly run for your shadow, and scream the  whole time it is chasing you.
PS. The one on the  bottom is eating the one on the top. These are Spiders found daily in IRAQ by our troops. Imagine waking up and seeing one  of  these bastards in your tent!!
lol.. not sure how true it is.. might do a little bit of research in to the camel spider.
Reminds me of one of those little creatures from the movie Aliens.
Ah - It must have been Tom Skerrit Hussein's beard that threw me :P
BTW: At the bottom of the Snopes page on the link above is a Camel Spider video - nasty little buggers. They do look just like a face-hugger.
Ripley!
if only they bit you n injected you with paracetamol or some useful drug... but nooo... they gotta inject you with novocaine... even morphine would be cool... just have one of em buggers on a leash n get em to bite you once in a while...
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
