  • Replies 56
Will be late Jan or very early Feb, I'm back down to tas on the 5th of Feb and the stagea is now up for sale
Probably will be in the next 2 weeks so watch this space for datails!
somewhere between using bad fuel once and my turbo failied andinstalling a hypergear/walbro/450cc injectors, nistune and taking too long to get booked in at a tuner, them delaying it an extra week because they couldnt get my front shaft out (they charged me an hours labour to not get it out)(took me 10 mins and i dont even have a jack), it was tuned st 306hp, 20 psi at 4000rpm dropping to 14psi at 7000rpm. on the way home from the tune i had a strange noise (i now think it was audible knock) and repeated check engine lights so pulled over about 10 mins after picking it, (pulled over as soon as the light came on) rang the tuner and he never returned my call. it never ran properly after that, did a compression test after trying all sorts of tests and came back at 96 167 167 167 167 167, tipped in some oil and came up to 130, i found 4 big problems once i had it apart, broken engine mount, cracked piston, valve about to drop, headgasket borderline blown, so yeah been a few months driving my mums camry.
Ok, got my car back (albeit with my optima battery completely f$%#@*d, and damn battery world not honoring the warranty.... So, should get a new batt today... I am still tentatively in, but my car will be going into the panel shop very soon to (finally after 3 years) get the roof rail replacement kit fitted!
I'll keep an eye on the dates, and try to make sure I have the Stag on the road for this meet... :)
Someone will have to take over this one for me, I'm heading to the uk tmrw for a funeral
Then I'm off to tassie 5 days after I return
Hopefully someone can take over and finish this so you guys get a meet out of it
Cheers, tom
Sorry to hear the bad news Tom.
I'll run a few ideas up the flagpole & see who salutes.
So everyone, either the weekend of 21/22 or 28/29. Can a few people vote for a day?
I would prefer a Saturday, but traditionally these things are held on a Sunday due to work/sport comittments etc, so maybe the first few in agreement can set the date & the rest of us will have go with it. In any case there's no way everyone will be able to make it no matter what date is set.
I've got a few ideas for the route but would appreciate someone reminding me of the usual GC meet point/s.
Cheers, Leon.
What's a guy got to do to generate some interest? Free drinks at lunch?
OK, Sunday 22nd of January, yes, just over a week away (unless a significant number of people actually speak up for a different date).
Route TBC.
sounds pretty good to me. Usual meet spot I we use is Coomera BP, but depends on where you want to go.... Mudgeeraba Shell is another good spot (and it's only 2 min from my place!!)
The route for Sunday is the reverse of a cruise from 2009. I'll post a route map in the next day or so, but essentially it is this:
South down Pacific Motorway with pickups along the way, Locations & times to be confirmed.
Exit around Elanora & head up Tomewin Mountain Rd
Over the top of the mountain & down into Murwillumbah.
Out thru Crystal Creek & up past Natural bridge & Numinbah Valley.
Back onto the motorway again at Nerang & head for home (or lunch?).
We'll have some stops along the way, so if you have any suggestions/locations for lunch please let us know.
Thanks to Micah for his input & especially for confirming the roads are OK to drive on as of a few weeks ago.
Looks like the usual apologies are coming in thick & fast, lol. Happens every cruise.
Hey Josh, I hope you can make it as I don't want to be the only M35 there.
For everyone else, it doesn't matter if your Stag is clean or dirty, modified or standard, straight or dinged - I'd like to encourage everyone to take a few hours to meet up & have a drive.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
