Well I hope for the best aswell, so far no mods stock with an exhaust . The car is 1993 and only done 117,000km's first owner since imported from Japan by DownUnder and I rarely give it kick.
So pray for the best and I hope I don't need do a rebuilt! I'll ask them to do compression test tomorrow at KYP.
Cheers for the help mate.
Pray it's the coil pack loom
You've replaced coilpacks. ignitor, plugs and cleaned your AFM. ECU is very unlikely but it is possible.
If it's not the loom ask your local garage to do a compression test. It will give you a very clear indication if you have done a main bearing.
Your mechanic is most likely able to tell you even without a compression test.
What year model is your 32 GTR and what if any work has been done to your RB26 ?
Not been running rich at all, using the same ones the NGK Laser Platinum that came out of the car. The coils should come today I hope! Got some yellow jacket coils. How do you fix the gap if there is one in the spark plugs?
Cheer guys!
How do you know the car isn't running rich if you can't even open an airbox or "fix" the gap on a plug?
Because i had a mate check it out and if you read before I have done it all to the littlest thing. But still happening, so I'm getting it towed down to a garage and getting tested and finding the error.
As per my other post -
Make certain you have checked the coilpack loom. (swap with someone else)
You have so far checked
Plugs - (gapped at 0.8mm, new cheap copper ones are good)
Coilpacks
Ignitor
AFM
ECU (unlikely)
Next is
Coilpack loom
Compression test
Somebody else said it - one of your cylinders isnt firing.
Taking to check the following things today:
Coilpack loom and
If not that than a compression test
Also is it common for the RB26 main bearings to GO?
If the main bearings goes, my car going be sitting there for months! :(
Coilpacks
Ignitor
AFM
ECU (unlikely)
Next is
Coilpack loom
Compression test
did you localise it to a certain cylinder using the method i told you to?Its really not rocket science man....let it idle pull each coil connector off until you find the one that doesnt make the car misfire anymore than it already does and there is your culprit......you need to pin point the cylinder thats misbehaving first then we can give you an indication on what to check next
Main bearings dont have anything to do with misfiring on one cylinder.......i assume you mean the rod end bearings,if so then you would know about it if its done a rod end bearing.....it would be knocking its tits off....
I have followed the steps you told me to do and I did that before I installed the new yellow jackets in. However after putting the new yellow jacket coils in the car its still doing the same thing. So i towed the car to a garage to find an error. They will tell me the results tomorrow morning and i asked them if they could tell me if the main bearing has gone, but from indications of the engine he said no (thank god!!). Maybe when i was pulling the looms around to move the cover i might of damaged the wires inside and resulting in failing to work again. Btw the cylinder that wasn't working was the third one from the front of the engine.
Cheers
Ok, getting my car back today and they have found what went wrong. All the steps I took changing coil, sparks and etc, might of triggered the ECU to stuff up. They found that the ECU was playing up and not sending signals to the cylinder. So the most unlikely chance of it being the ECU was the one. What a run around I tell you, just so happy it was fixed and over YAY!! :)
Cheers for all your help guys, wouldn't know what to you without everyones help!
Amon
Yep, a simple ECU restart did the trick. He said it could of happened when you restarted the ECU by taking the neutral out, putting the lights on to drain the power and reconnect it back and causing a spark making the ECU to malfunction.
What did they do to fix it?
Does this mean a simple ECU reset may have fixed the problem?
Cheers mate, yep it feels awesome to have the beauty back on the road. Also I 4got to add the mechanic said when he pluged his computer to scan the car, the car didn't come up with the O2 sensor registered but after restarting the ECU it was there. Should I may as well replace the O2 sensor?
Once again thank to everyone who has helped me :thumbsup:
Congrats :thumbsup: must be a good feeling.
It's not something I would have bet on as being the issue. Pleased to hear the good news.
SargeRX8 was on the ball though
i have same problem dont drive it around untill you change your catalytic converter, if you want to drive it around take it off and hollow it out or else if you drive it and boot it you will put strien on your engine as i was doing untill i hollowed mien out and when i check it it was completely blocked so i had to take the honeycomb stuff out of it untill i bought my new one which came in today and installed in satourday hopefully it all goes well, hope this solves yours but defiantly sounds same problem as mine, when driving it struggles when accelerating and some smoke comes out when booting. you notice loss of power too. if it is the cat i bought a bolt on high flow 3" from justjap its called catco. so check your catalytic converter.
I'll have a look into it mate cheers, car running fine now and at boost I don't feel no loss in power. I'm getting custom exhaust system in couple of months so I won't worry so much yet.
Cheers
Amon
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
