Buy my shit!!!!
Take 10% off all the prices below, I need this crap gone from my shed!!!
Items still for sale (Pictures on page 3):
Hubs front only $150 or $300 front and rear
Rear sway bar $50
Rear cradle $100
-no brakes or diff, one bent control arm, includes hubs
Suspension $130
-Front with lowered springs and rear HKS suspension. Rear boots are torn but otherwise fine, no leaks.
Clear side indicators $40 pair
Side skirts $100 pair
Fog lights $60 pair
Rear wing $100
Passenger door $130
Passenger side mirror $30
19 inch rims $700
Maxxis rubber with heaps of tread.
Alloy radiator $140
Dash pad $150
Wiper and indicator stalks $15 each
Passenger airbag $100 prefer pick up only
Ignition barrel with key $50
Front & rear seatbelts $40 each or $130 for all four
Nismo gearknob $40
Din pocket $20
Climate control unit $40
Sony Xplod Stereo $60
-Comes with remote control and manual
Blitz turbo timer $50
B/C pillar trims $30 each or both for $50 (awesome condition)
ABS unit $80
ABS bracket $20
Rb25 AFM $50
Aftermarket castor rods $60
Power steering rack $50
Nissan tool kit $15
5Zigen tip $40 (muffler is damaged)
Cat to muffler 3” exhaust pipe $40
  • Replies 139
Now sold:
-Fog lights
-DIN pocket and stereo brackets
-Suspension
Still for sale:
Rear sway bar $50
Rear cradle $100
Rear wing $100
Passenger door $130
19 inch rims $700
Alloy radiator $140
Dash pad $150
Nismo gearknob $40
ABS unit $80
ABS bracket $20
Rb25 Series 2 AFM $50
Nissan tool kit $15
hey mate how much for the diff the drive shafts the rear cradle and hubs and i can pick it up this weekend
diff and shafts sold mate
still got the cradle 100 bux including the hubs, come and get it out of my yard!!!
Afm sold and posted...
Still for sale:
Rear sway bar $50
Rear cradle $100
Rear wing $100
Passenger door $130
Alloy radiator $140
Dash pad $150
Nismo gearknob $40
ABS unit $80
ABS bracket $20
Nissan tool kit $15
Cat to muffler 3” exhaust pipe $40 pick up only
Turbo timer sold (but i have others for sale)
Indicator stalk and alloy rad sold
Still for sale:
Rear sway bar $50
Rear cradle $100
Rear wing $100
Passenger door $130
Dash pad $150
Wiper stalk $15
Nismo gearknob $40
ABS unit $80
ABS bracket $20
Nissan tool kit $15
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
