what do you think of the rb26 miata mx5?
72 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hello a few buddies of mine started this project when I met them about 4 years ago ,a RB powered Miata mx5 !!!
at first we installed a rb25 neo motor had to do allot of r&d and we went 9.8 @ 143 in the 1/4 mile. while all that was going on we had been working on a rb26 building it from head.to toe! The car now has a RB26 fully built with a powerglide 2 speed gearbox,GM differential,custom made axles especially for this car from the DRIVE SHAFT SHOP AXLES,a pair of 26x10.5 Mickey Thompson full slicks , Garrett gt42-45R dual ballbearing turbo,c16 race fuel,26psi making over 800hp and 600+ ft.lbs.tq
let me know what you guys think!
this was our 9sec pass On the 5 speed manual gearbox (still had the rb25)
This was our first pass on the powerglide gearbox we didn't know how the car was going to react we wanted to see what it did so we could dial in the launch and everything else after
We were so happy the car did so great on the first pass!!!!! (RB26 set up )the car is capable of doing 8's , the 15th of January we are going to import face off here in SoCal we are definitely going 8's !!!!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/
  • Replies 48
Hmm thats a very interesting conversion. Its amazing how many different engines have gone into mx5s over the yrs. I personally would've gone a TT Lexus quad cam. But hey each to thier own :)
Edited by Raysboostin
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6173737
This is another video we went 10.1@91mph driver let off half a track and step on brakes at the end we were in a class for import face off we didn't wana get discualified lol Edited by nismorb25neo
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6178611
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now alloy if sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181828
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now allot of sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181984
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
