Hey guys,
i've recently lowered my R31 and since I've been getting a bit of vibration from the tailshaft, I've worked out by lowering it i've straightened the tailshaft out and they're meant to have between 1 & 3 degree angle.
I've tried spacing the transmission crossmember out with washers, first 3, then down to two, now i'm dawn to one washer on each bolt, but its still vibrating.
i've heard its a common problem but can't find a solution. I was wondering if anyone knowshow to fix it.
CHEERS
https://www.sau.com.au/forums/topic/387009-r31-tailshaft-vibration/
Have you checked the centre bearing? When they wear, you will get a pretty good vibration. What about the condition of the uni's? Are they greasable?
By putting washers under the gearbox mount, you are misaligning the wrong section of the shaft, you'd be better shimming the centre bearing to reduce the included angle of the shaft, rather than increasing the misalignment.
Also, it might be worth looking at an adjustable panhard rod to centre the diff, as lowering pushes the diff sideways. This is another source of misalignment.
What is the condition of your rear upper control arm bushes? And lower arm bushes for that matter. The upper arm bushes are a common wear item and could be causing the pinion angle to be larger (nose of diff pointing down) increasing rear uni angle.
Good luck.
Edited by Daleo
Yep all the rotating parts have worn-in one way and changing the angles has upset it.
It can look ok but angles don't need to change much.
Or for that matter even new parts may wear quicker in the altered setup.
I agree with the boys miss-alignment causing vib.
and get an adjustable panhard rod
Good luck.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
