Hey guys,
i've recently lowered my R31 and since I've been getting a bit of vibration from the tailshaft, I've worked out by lowering it i've straightened the tailshaft out and they're meant to have between 1 & 3 degree angle.
I've tried spacing the transmission crossmember out with washers, first 3, then down to two, now i'm dawn to one washer on each bolt, but its still vibrating.
i've heard its a common problem but can't find a solution. I was wondering if anyone knowshow to fix it.
CHEERS
https://www.sau.com.au/forums/topic/387009-r31-tailshaft-vibration/
Have you checked the centre bearing? When they wear, you will get a pretty good vibration. What about the condition of the uni's? Are they greasable?
By putting washers under the gearbox mount, you are misaligning the wrong section of the shaft, you'd be better shimming the centre bearing to reduce the included angle of the shaft, rather than increasing the misalignment.
Also, it might be worth looking at an adjustable panhard rod to centre the diff, as lowering pushes the diff sideways. This is another source of misalignment.
What is the condition of your rear upper control arm bushes? And lower arm bushes for that matter. The upper arm bushes are a common wear item and could be causing the pinion angle to be larger (nose of diff pointing down) increasing rear uni angle.
Good luck.
Edited by Daleo
Yep all the rotating parts have worn-in one way and changing the angles has upset it.
It can look ok but angles don't need to change much.
Or for that matter even new parts may wear quicker in the altered setup.
I agree with the boys miss-alignment causing vib.
and get an adjustable panhard rod
Good luck.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
