  • Replies 85
oh ok when i say chopped its usually a run from zip to 80 and I was about drivers side door level when i backed off. this was against a bf ute with a system under it. I've never had any trouble with later model commodores and falcons (in p plate trim of course) generally walk away from them when i hit second lol :).
(word of warning el & ef xr6s can sometimes be very suprising :P)
i'm assuming that most of the aussie 6's you are racing are autos? is your car a manual by any chance? if so, then that is a somewhat unfair comparison. go up against a manual falcon/commodore and you will get chopped. just like auto skylines, auto commodores/falcons are noticably slower than the manual versions. although if you go up against an auto with a shorter diff ratio in it (since they are stupidly tall in standard form) and it too will beat you.
Mate has a 15.3 sec VR commodore, it has a 3.89 diff ratio in it and beats my car to 100kph easy, after that though its like he's standing still :P
IMO Hondas and their little vtec engines are far less than impressive... Vtec really isnt that great... When it kicks in all that i feel is a slight change in the exhaust note and an urgency in the tacho, as far as the actual car, it still feels slow - acceleration is still slow and the lack of torque makes the whole car feel gutless.
I used to be a "Honda Boy", but after having owned two vtec civics in the past (eg and ek) and having driven all the Honda "sport" car models (except nsx) I grew a disliking towards them. d16, b16, b18, k20 and h22, had my experiences with them all and they all suck...
Although i have driven an S2k and those are nice, my only gripe about the car is that it is overpriced. Apart from that, the car is nice. I'm also pretty certain an nsx will be a nice car as well - just need to get my ass in one
My bf's supra does laps aroun my 34 (both na)
Just like my car would run laps around his supra :P
that civic must have a bit of work done to it (or possibly an engine conversion from something like an integra or prelude), as well as some sticky tyres
don't suppose you've taken any notice of the trap speeds of it?
The civic i mentioned in my first post had pulled 3 car lengths on my NA Z, and i trap 97MPH so i bet it would have done 100+mph trap, they are fairly quick when done up properly.
Edited by Super Drager
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
