Yes,
I did these things before but not on a Skyline. (on MacPherson struts)
You start on one small thing, and in the end you rip the whole car apart.
With the Skyline's suspension matters seem to be a bit less painful though. :)
Once you have the Whiteline bars, this is always something you can add at a later date.thumbsup.gif
Edited by Torques
  • 4 weeks later...
Yes, I did this before ... alas not on a Skyline.
It's mostly the same story, you start a small thing and 'while at it' you start other sub-projects since it all is conveniently taken apart anyhow :)
Someone told me that the adjustable bars may be problematic due to the fact that the angle to the link may become extreme.
Is this an issue?
Thaaanks!
Is this an issue?
Thaaanks!
The Whiteline bars go through a lot of initial testing; and the parts you'd be looking to fit have been around for a while now, so that's a hell of a lot of cars doing "in the field" testing.
If there were any issues; I can assure you that Whiteline would've long ago spotted and corrected any potential problems.thumbsup.gif
I haven't personally fitted a set of Adjustable bars to an R33; but I have on an R34, which shares the same suspension architecture. I had no issues with alignment or fitting.
Bearing in mind the distance between the two adjustment holes on a BNR11XZ or BNR11XXZ is only 20-30mm; and the point where the OEM link would sits, is right between the two; misalignment is negligble.
With regard to the BNF24Z; it has 4 adjustment holes.
The rear two, fall directly below the OEM link position (with the same centreing and 20-30mm spacing as the rear). The front two adjustment hole are accessed by flipping the link around to face the front; so the link alignment is retained. This is why there is a larger gap between the two centre adjustment hole in the pic below.
Hello there,
Thanks for the explanation and pictures, much appreciated.
So compared to the OEM part the holes are either more 'left' or 'right' ?
Is this the same with the non adjustable bar?
Daleo, can I ask if these whiteline swaybars have much effect on the way the car rides over normal bumps and undulations when driving straight? Or does a mod like this only really get noticed when cornering hard? What I mean is, would stiffer swaybars make a car more rough riding when just pootling around town or would you only really notice when fanging the car in the mountains?
They do make a difference you can feel; but I wouldn't say it is a negative change.
Over single wheel bumps (potholes driveways) you do notice; because you are effectively increasing the spring rate of that wheel. This generally manifests as additional resistance to bottoming out and slightly firmer feeling suspension.
Over two wheel bumps (undulations and speed humps) you won't notice them at all; because the bar is unloaded, and just effectively floating.
Bars generally don't make the car ride rougher around town; in fact after adding heavier bars to my car, I was able to significantly soften the damping of my coilovers. This is because I didn't need to use the damping to cover up the sloppy response on turn in. I've had similar feedback from other people who've fitted bars.
So the end result in my case; was a more supple compliant car, that was much more able to follow the contours of a corner, rather than just crashing over them. Smoother, quieter, and above all shitloads quicker and composed in corners.
hey just haveing a read i have a R34 i installed both these sway bars today went in peace of cake best bang for ur buck thing to do i also brought them of this guy with no problems i can upload some pics of them in if it helps you decide :)
rear is piss eazy just drop ur exhaust down and it simple swap front i needed to drop the caster arms down to get to a bolt apart from that its ezy
Hey Cody, Glad everything went well mate. Thanks for the feedback mate; really appreciate the kind words.:thumbsup:
Having to remove the caster rods is the only frustrating part of the job really; but no other way to get at that saddle bolt.:spank:
Cheers, Dale.
  • 10 months later...
Can confirm that rear 32 GTR sway bar will fit 32 gtst, fronts how ever will not.
I found this out after dropping castors arms and trying to fit gtr bar and there is no way said bar will fit.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
