<iframe width="420" height="315" src="http://www.youtube.com/embed/UyDWsDmYejA" frameborder="0" allowfullscreen></iframe>
Is it true can you get a 40kw gain from a 1300$ Nismo tune? I have asked the producer of the video and he said that when he brought it in, it was dyno'd at 93RWKW at when they finished it was dyno'd at 147 RWKW.
It seems to be one of those too good to be true videos, others opinions?
https://www.sau.com.au/forums/topic/387440-r33-rb25-nismo-tuning/
May as well just buy a proper ECU for that price. That way if you decide to turbo your car later on or change something major you have a tuneable ECU and can get the most out of it
It seems a bit to good to be true having that much jump, but I dont know anything about it so cant say that its defenitely to good to be true
No such thing as a "nismo tune". They're using nistune in that video and that R33 IS NOT STOCK. It has big cams and camgears dialled in for maximum power, good luck trying to replicate those results ;)
^ +1 thing isn't stock, probably a very healthy motor as well.
this is from the comments of the clip:
Amazing results with a nistuned Z32 computer modified to run the R33, this cheap alternative is conducted in house and retails for $1300 fitted and tuned,
as the R33 computer is not a chippable board. the first run is standard setting with aftermarket exhaust 96.3 kw, then after a nistune chip and tune 121.5 kw!
then a set of camshafts and a nice set ENVY Dyno vernier cam gears inlet and exhaust doing away with the variable valve timing showed amazing improvements @ 147 kw!
thats almost the power of the turbo engine kids!!
So they removed the variable valve timing that helps with mid range power (what you use for the street) to get that extra amazing few kws up top which wont feel like much.
in the end, you will pay equal or more for that then for a standard turbo motor.
even the 25kw or so gain just from the nistune is somewhat questionable. the 121kw or whatever it was (too lazy to scroll up) seems roughly right for a tuned power output, but the 96kw original power run seems somewhere between 5 to 15kw too low.
I've seen this vid aswell. As dragger said the cars not stock (big cams, cam gears, exhaust (assuming extractors :P) just that stuff alone will set you back over 2000 for parts and fitting. plus the tune ontological your looking at around 3500 grand to get the 40ish killerwasp gain.
for that kind of money you could almost buy and install a standard det which would make more power. also if your on your ps cams ect make the car illegal anyway lol.
the dunk results could be true, but for the gains not overly worth it :)
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
