Wheels factory R33 GTR forged 17*9 with 255 width tyres near new $1500
Power FC for R32/R33 GTR, includes hand controller original packaging and manuals $800
Factory RB26 Airflow meters 3 good ones and 1 intermitantly faulty one available $80 each
Factory Air Box R33 GTR, Factory Snorkle R33 GTR, K&N Filter for standard airbox
post-33414-0-53842700-1325984656_thumb.jpg post-33414-0-58820500-1325984665_thumb.jpgpost-33414-0-32384600-1325984663_thumb.jpg
Rear Brake pads R33 GTR, Factory brake lines, Factory cam gears
Factory Coil Packs, assume working else previous owner would not kept them
Dumps & Turbo's, 1 turbo blown, sitable for rebuilding
post-33414-0-43417600-1325984731_thumb.jpgpost-33414-0-53666700-1325984874_thumb.jpgpost-33414-0-24593500-1325984871_thumb.jpg
R33 GTR Vspec 4WD computer, had intermitant issues but were not fixed by replacement, so assume it it OK, at your own risk.
Factory Intercooler piping
Sparkplugs unknown quality
Near new sparkplug, platium. Used for less than 100km but replaced by copper by tuner due to some technical issue with the car since fixed.
Factory Fuel pressue reg???
Factory Washer bottle
https://www.sau.com.au/forums/topic/387528-gtr-parts-inc-wheels/
Updated, had to leave before completing all prices. Discounts possible if you want multiple items.
Airbox $150, Snorkle $60, Filter, $40 or ($200 for all)
Brake pads (rear) $10, brake lines $10
Cam gears $20ea
Coil Pack $50
Dumps and Turbo's $50
4WD computer $40
Intercooler piping $10
sparkplugs $5
Near new platium spark plugs $10 ea or $50 for all
Fuel pressure reg??? $5
Washer bottle $20
Shipping extra, just tell me what type, insurred registered etc
Lots of stuff gone. Here's an updated list of available parts.
AFM's $80 each
Brake pads (rear) $10, brake lines $10 (For this price have them as spares, oem approved etc)
6 Coil Packs $50
4WD computer $40
sparkplugs $5
Washer bottle $20
(take the lot, make a stupid offer, I can only say no)
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
