Basic question really, for my 1995 GTSt I need a new set of discs and pads. Does anyone know how much it will cost to replace all the discs with new items? Basically I have been told this will cost around $1K, for that price I might as well go all out and buy a second hand set of Brembos. Any advice?
https://www.sau.com.au/forums/topic/38769-new-brakes/
hey mspec, check out the DBA rotors www.dba.com.au, they are better and cheaper than the nissan items. Not sure who sells em in Melbourne, Racebrakes in Sydney have a discount for SAU members
Pads? Bendix Ultimates, about 200 for the set. More details in the FAQ http://www.skylinesaustralia.com/forums/sh...ead.php?t=17760
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786271
Thanx for the info, I remember seeing the DBA disks in an import mag a while back, I was trying to find the mag :) I cant find any prices online, but they are available from pretty much anywhere; Autobarn, Bursons, Repco, Supercheap and so on! My last set of pads were Bendix and they did the job well. They also do not cost much which I am sure you are aware of. Anyway thanx again for the info mate!
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786409
You mean slotted & cross-drilled? (suitable for street driving only, not track work).
Urmm not sure maybe an extra $100 or so... Buster has them on his car.
Edit: I got my DBA4000 Slotted Rotors in a group buy from on here for ~$845 around 12mths ago.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786428
To be honest im not sure what the difference is between the Club-Spec 4000 and the 'longlife' rotors, I believe the Club-Spec 4000 is the newer model as they are only about 15mths old where as the 'Longlife' appear to be about 4yrs old.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786441
Okay fair enough, I will find out on Monday when I go price hunting :) Just doing a little extra research before hand. By the way are you guys quoting for just the front disks or all round?
Uniqueautosports is asking $795.00 Per Pair of R33 GTR DBA 4000 Series Front Brake Rotors.
http://www.uniqueautosports.com/pricelists...%20steering.htm
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786446
Don’t recon the DBA 4000 Series are worth it. Got a quote today down at Autobarn, they recon the front are about $540ish each and the rears are about $450ish. At this price its cheaper to import a good condition set of Brembo brakes. I have used these on my GTSt in the past and there awesome, the last set was sold but I think I will get a new set. For about $2K you can get a full set of GTR (Brembo) discs, calipers and pads, so this is what I will do. Anyway guys thanx for the help.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-787028
MSPEC - I am in the same position as you, and am going to have my brakes done on Monday. I can answer some of your questions:
1.- DBA Long life Series and DBA 4000 Club-Spec Series are not the same rotors.
2.-changing the standard rotor for a drilled/slotted DBA one with the same calipers and pads will not really improve braking that much, but may reduce brake fade to some extent under severe braking conditions. - Changing to good pads will improve braking more than changing the rotors. (rotors will help reduce brake fade)
3.-How wide are your current rotors? the DBA specs are incorrect and state that the minimum thickness is 30mm. (It should be 28mm - you can check with Nissan to verify this).
In my case this now means I can keep the standard rotors for a little bit longer and spend the money on machining and pads.
The prices I gathered indicate that DBA front rotors cost $850 fitted, and standard ones (from nissan) were cheeper. Rear disc rotors were about $500 from DBA.
I believe there is a shortage of DBA rotors at the moment for R33's as they all list them but have trouble locating a pair. I also found out that some GTR rotors are almost identical to GTSt rotors, but you can get some useful information from Racebrakes in Sydney.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-788274
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
