Hi guys , stripping all the parts off my 32 after someone wrote it off. :( Was one of the cleanest 32's out there that I imported from HKS in Japan.
The car prior
The car after
Everything is going ,
Interesting parts -
POWER FC with Hand controller and FC Hako Usb conection and tuning software ( ECU Also has a RacePace tune on it) $850 delievered
Splitfire Coilpacks (Around 3000K's use) $450 delivered
Bride replica seat with rail $400 (Would preffer pickup)
HKS Speed limit Defender $150 delivered
Nismo 320KMPH cluster$ 200 delivered
Bee*R Rev limiter $200 delivered
Tein Winding master Coilovers $800 bucks (They are amazing)
Aluminuin radiator $300
HKS SSQV Bov - make me an offer
HKS mushrooms make me an offer
Also have Cusco Controller arms , strut brace , braided brake lines and heaps of other stuff if you want to come past one day and check them out .
+ The rest of a '93 GTR including all switches, door trims , dashboard , N1 bootlip , pods and spoiler. - EVERYTHING IN ABSOLUTE PRISTINE CONDITION.
Engine has around 145- 150 thousand K's , made 265RWKW @ 14 psi with intake , exhaust , coilpacks and power FC.
Any parts that you need , let me know and ill tell you if i have them .
Any pictures that you guys need , ill take , just very bust at the moment with work.
My Mobile is 0434112724 , if i dont asnwer im at work , but feel free to send a text and ill get back to you ASAP.
Make me an offer.
Thanks guys.
EDIT:
Parts that are gone :
Dashboard
Nismo Cluster
gauge cluster
AC controller
N1 Bootlip
Drivers STANDARD seat (still have the Bride)
Both Door trims
https://www.sau.com.au/forums/topic/387691-wrecking-r32-gtr-vic/
  • Replies 48
Posted Images
front brakes?
Yes , non v spec calipers , RDA rotors and A1RM pads
500 all up.
Ive got a potential buyer for the whole car though , so ill let you know tommorow .
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
