So Guys it's been a long time am I right? :D
Well In this case Of Gemma's absence ill take it on board to organize one of the good cruises that would normally occur a few times every year.
FINAL DATE AND ROUTE CAN BE DISCUSSED! (Shout out your suggestions guys so we can all decide what works best, P.S once final route has been decided I will Print 50 Or so maps for everyone on the day)
INFO!
Meet: Meet at 9am at KFC cross roads (camden valley way). Head down to Maq pass. (South guys you can orginise a little meet so you don't need to drive up here and then we can rondevu at the school.) Then to our destination of crn or jambaroo rd and illawarra hwy, Roberston. Route: Straight down Hume hwy from cross rds, left at picton rd. Right at Princes Hwy, Right at Illawarra Hwy ect ect. The cruise generally takes about 1.5 hrs to get to Robertson pie Shop.
What to bring: bring a full tank of fuel, Camera, Money for pies etc, they do have eftpos last time I was there, A good attitude and a smart head, this is an un-official SAU cruise, Anyone and everyone is welcome but all club rules apply, there will be zero tolerence for "hoon" behaviour and anything that could bring dispute to the clubs name will be reported as well as your number plates to the police :) so lets have a fun, Safe and exiting day!
HOPE TO SEE YOU ALL THERE!
https://www.sau.com.au/forums/topic/387899-cruise-to-robertson-pie-shop/
  • Replies 212
Posted Images
I'll be going up tomorrow for a run, there was a rather nasty accident at the bottom of mac pass recently. Those pies are golden.............
yeah that was on Sunday, i went down with a few cars for a cruise and it was blocked off.
had to detour through Jamberoo Rd up the hill which was wet and foggy, made it a very interesting drive up the mountain in a 250kw Skyline :O
saw alot of cops patrolling through the area as well so take it easy in there guys.
im off from the 19th to the 24th of this month, anyone up for a small 'recce' cruise before i lose my licence for three months on the 25th of jan?
any one of those 5 days would be good for me.
So which one of you guys with a GTR is going to help me show a lady friend of mine that skylines shit on all things commodore? ... ( can somone volunteer to take her up the Pass, After we stop to regroup at the school just before jamberoo road) Yes she's hot.
Sure thing :thumbsup:
brb putting gtr badge on gts-t
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
