Hey guys
I Was just driving to civic and my controller is running unlimited boost for some reason. I haven't changed any setting or anything
It hits 14-15psi then jolts the whole car like the engine couldn't keep up. Checked the hoses to the controller and they all seem fine
Ideas?
Thanks guys
https://www.sau.com.au/forums/topic/388030-unlimited-boost/
Turned the settings all the way down and it runs a solid 5-6psi now I just been WOTing it down the back streets and slowly setting my low setting in the controller back up
It's now pretty much got a flat 9psi programmed back into it.
Really weird because I didn't touch the settings at all and all of a sudden it started hitting 14psi on my low setting which was programmed at 8psi
Can anyone else hear their solenoide ticking away as they put their foot down? It sounds like someone clicking a pen really quick and can be heard in the car quite clear
https://www.sau.com.au/forums/topic/388030-unlimited-boost/#findComment-6185902
You should be hearing the solenoid. That is weird and freaky bout the unlimited boost. Glad you got it sorted and didnt break anything!
Mine was giving me unlimited boost when i accidently mispiped it, had the wrong holes on the solenoid, but i was watching and paying attention cos was intending to set up the controller.
https://www.sau.com.au/forums/topic/388030-unlimited-boost/#findComment-6186517
Haha its bloody scary!
I was just hitting Northbourne and gave it some and it just kept spooling
Then the whole car just went clunk and jolted
Girlfriend was like "WHAT THE FU$% DID YOU DO THAT!"
She thought I did it on purpose lol
I'm lucky that when I run with nothing connected to the actuator my ecu hits overboost cut :)
https://www.sau.com.au/forums/topic/388030-unlimited-boost/#findComment-6186656
Yeah that's what I think they are way over priced
I will just get this nistune up and running then later when I throw more upgrades then it can handle I will sell and upgrade
People are running ~400rwkw with Nistune.
I don't think it has a limit for power or basic mods. It's when you wanna get complicated by plugging a wideband o2 sensor into it and stuff like that
https://www.sau.com.au/forums/topic/388030-unlimited-boost/#findComment-6187758
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
