Ok
time has come
i need a new clutch because my current one has put immense pressure on my left knee for a year now
and i have constant knee pain :closedeyes:
i currently have a xtreme single button 5 puc push button clutch
"highly resistant to the most agressive clutch use and sustained high temperatures."
thats a exerpt from the clutch ad
which is ******** because it takes 2 seconds for the POS to burn up and start shuddering so its finished
so what are some good clutchs that wont burn my bank or destroy whats left of my knee cartilage
https://www.sau.com.au/forums/topic/388238-clutches/
10" NPC they come in a ceramic or oganic variety and wont kill the bank
$650 for the ceramic (usually)
i would have to call for an organic price will double check price for ceramic also
what would be ok for like normal use but isnt to soft?
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6188282
I've gotten a full face organic from Madaz and its perfect for daily driving. You'll notice that switching from a stuffed clutch to a new one there will be extra pressure but there are a couple things you can do to help this, namely get a nismo slave cylinder, braided clutch line and a clutch pedal brace. The nismo slave will make it easier to push down on, and the line and brace will make the action more precise (optional really)...
+1 to Madaz's clutches - excellent price and great product - Mines good for up to 300kw...
-D
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6188297
+1 for npc and all the extra nismo bits that dohmar speaks of. We've had this discussion many times before and it always comes back to 2 options. Spend the money on a coppermix for an excellent clutch or spend less than half that amount for a locally built product with a rep to match the coppermix.
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6188387
I too vouch for the NPC. I have an organic 10" one behind a SR20 and was told the clutch was good for 400hp, drives very nice and has a good pedal feel. In the next few weeks I should know how well it handles close to 400hp too.
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6188881
I too have been NPC'd by Steve , no idea how it works till next week. had to find another mechanic besides the local ones (muppets) but the day after the clutch the car is being dumped on the dyno so the light flywheel would be a bonus.. the curent one(not NPC) is getting touchy, and slips a bit on hard boost in 3rd
, not worried about too stiff, your soft if you cant use a hi pressure clutch in traffic in a nissan , try old skool hi pressure clutches with no hydraulic help now thats a workout in traffic
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6189396
I also have a NPC clutch from Madaz, been in the car for about 15 months being daily driven and it hasn't missed a beat. ever.
Its a ceramic one, not sure if its 9.5 or 10 though, can't remember lol.
edit: while I'm here, I'll need another one shortly for my new R32, needs to be able to hold 260rwkw on a RB20, and needs to be RB20 gearbox friendly.... lol
I dont need it yet, but if you could chuck me a ballpark that would be good Steve.
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6189921
I have been using a clutch I bought off ebay for almost 2.5 years now. Car has made close to 300 rwkw and done 4 track days. Clutch is still going all strong. I paid something like $300 delivered. Below is a link for something similar. Get the Stage 4 clutch and it feels no different to a stock clutch.
http://www.ebay.com.au/itm/F1-RACING-6-PUCK-CERAMIC-MIBA-STAGE-3-CLUTCH-DISC-JDM-NISSAN-SKYLINE-R31-R32-R33-/160707735886?pt=Motors_Car_Truck_Parts_Accessories&hash=item256aed714e
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6189982
had isssues with the npc clutch, but a quick call to NPC sorted it out , the dowel pins are made extremely tight when combined with NPC lightweight flywheel. and needed a light tap to clear pins they make them so the ends are tight but fit perfect on the bolt up(angled a tiny bit almost)
tested on my nismo flywheel fit easy as no fuss
ended up on dyno with 189.7kw @10psi with quick tune and shagged x force cat blocking flow , could easy pass 200kw with new cat and more dyno time on factory pump and injectors
https://www.sau.com.au/forums/topic/388238-clutches/#findComment-6202066
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
