Hi guys, just a pretty simple one I'm hoping a few people will know. How much do the R32 GTR standard Injectors & fuel pump flow? give or take.
Read up that they both easily will do 250rwkw, and then also read up that they can push 300rwkw without having to upgrade. Your thoughts?
Injectors, not a lot more than 250rwkW on standard pressure. Maybe you can stretch to closer to 300 with some extra pressure. Not so sure about the fuel pump - but it's fair to say that if it is standard and the original one the car came with, it would be wise to replace it if you want to push past 250rwkW, especially if you try with higher pressure (which will cost flow off teh top of the pump's capacity). cheers
Stock injectors/cleaned/working right - with a NEW pump - 280-300rwkw. They can do up to 330-340rwkw with a minor bump in rail pressure.
But again must be stressed - you must replace the pump as by now they are 20 years old if still factory. So trying to push anything is a bit too risky.
Also you could have injectors that require cleaning etc. So it is very hard to say.
yea, thanks for that. I thought replacing the pump is a smart idea. Im hoping with a drop in Nismo one, with standard injectors that have been cleaned etc, 300rwkw is within reach :)
What's the best Drop in upgrade injectors for a R32 GTR under $1000?
Would is be wise to get a nismo fuel pressure regultor too? and is standrd fuel rail ok for 300rkw? sorry for all the questions. just trying to make sure I invest my money in the right areas.
There are these nismo 600cc, but they seem sooooo expensive.
http://www.ebay.com....=item337044f027
Edited by 91BNR32
1. as what has been already stated stock rail is fine,.. Sh!t u can run 400rwkw +++ through it if u wanted
2. Dont need the regulator unless your keeping the stock injectors, people use the regulaters to pump up the rail pressure when they need a bit of extra fuel to get them over the line
3.Stock fuel pump is big enough, but as a safety factor get a new one to feel better (youll probably end up replacing it sometime in the future anyway) as a reference nsimo will support 400rwkw for any future mods
4.if ur goin to buy injectors, have a look around the forum for a good set (see if u can get a set that have been tested and cleaned ie spray pattern,flow etc) i sold my nismo 550's for $500 bucks from memory
5. as i stated in the other post check out rhdjapan.com, they sometimes are doing deals on sard injectors, got my 800's for $660 plus delivery
i will have some nismo 600cc injectors for sale in the next week or too as i will be upgrading
bought them off GTR_JOEY last yr
for safety as others have mentioned, fuel pump and a minimum of 550cc injectors.
cant really go past the nismo gear, direct drop in replacements always fit perfect :thumbsup:
and i also had a second set that i sold to Nick
they were flow tested and cleaned and come up well, those ones came off a 350rwkw engine and only sold them to put my 800s in
Whats the deal nick, not big enough mate?
Edited by GTR_JOEY
Just running new engine in with the 600s then going to id1000s
was reaching 90% inj duty on cold days and i personally i dont like the duty to be above 85%
plus the 1000s give me the option of eflex/e85 down the track :whistling:
standard injectors on my R32 GTR ran out at 19psi and 293rwkw, I changed the pump and FPR, which gave me some head room, but when you change the pump in a R32 it is a good idea to rewire the pump as the 2 speed for the pump tends to fail, I ran a wire off the alternator to a 20 amp fuse then under the car to the boot to a 20 amp relay (using the stock fuel wire to trigger ) and into the standard plug at the top of the fuel tank.
Higher fuel pressure helps with atomization so don't be scared to bump fuel pressures
Good choice, no old tuner swears by them and says he can get a better ideal with them over the 600 Nismos I have in the 34.
Yea seeing alot of people go to the id injectors having awesome idle stability
how much power were u making with the 600s?
whos doin the tuning for you?
we'll have to go for a cruise when i get eventually get mine finnished..... whenever that is
was making 335kw at the wheels on 22psi with -9s, stupidly responsive
Pulse Racing in Menai did the build and are tuning it :thumbsup: have been doing all my work
hahaha yea for sure how long till its completed??
sounds like a weapon, keeping the -9s then?
its at performance exhaust at Northmead atm, then back to Unigroup for the tune and a couple of bits and peices
hopefully by the start of next month but not holding my breath...
hell its been nearly a year since i sold u those injectors, and it had already been off the road of 6 months haha
yea keeping the -9s i love the response and has power all the way to 8000rpm
ahhh nice 3.5 or 4inch exhaust??
hahaha yea its been awhile chop chop!!!
from what i remember its going to be a beast well once its on the road :P
to responsive for my liking those -9s heh heh
got a 4 inch dump coming off a single then merging into a full 3.5 inch system with twin gates and a cannon as a muffler lol
a run against ur e85 -9's will be a good tester to see how it measures up :thumbsup:
So will be quiet :P
Yea would be a good comparison
Will try 98 first hahaha
Hopefully you don't have toooooo much lag ;)
Hey mate, will the nismo 600cc you have need cleaning and flow testing? Might be keen on them. How much you looking at??
http://www.rhdjapan.com/nismo-high-flow-volume-injectors-set-top-feed-600cc-6-cylinders-11100
""Low-resistance type: Type with internal resistor to reduce the suitable operating voltage (approx. 5V types are most common)
Requires ECU upgrade""
What does this mean?
We're cleaned and flow tested before I bought them and have been faultless in operation on my car, only used for about a year
Looking at around $600 for them but am negotiable on price
Regarding the above post, basically saying they are straight drop in and you will require a programmable ECU ie power fc to set the appropriate injector size so the ECU knows how much fuel to give
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
