Apologies I thought you were unaware of the rb34 kit and had just noticed the rb32 kit.
Why would you choose the rb32 over the rb34? Cheaper? Rev higher?
RB34 requires some block machine work AFAIK, RB32 should be bolt in and go.
  • 2 months later...
on the spool webiste they have done a comparison chart between a rb30 and their rb34. bit of a increase has been achieved. http://www.spoolimports.com/articles-1/rb34det-results. as for brand comparisons dyno charts, it will probably never happen as not one workshop will see the same style of car, same style of setup do to this unless they cough up the coin themselves to carry out the tests.
on the spool webiste they have done a comparison chart between a rb30 and their rb34. bit of a increase has been achieved. http://www.spoolimpo...rb34det-results. as for brand comparisons dyno charts, it will probably never happen as not one workshop will see the same style of car, same style of setup do to this unless they cough up the coin themselves to carry out the tests.
This thread is not about RB34. There is already an RB34 thread.
I'm surprised they didn't lose any hp in the top end due to the smaller bore/stroke ratio. I would say there head was flowing quiet well!
The rb34 bore/stroke ratio is less than an xr6t and those things just don't like to rev over 6500.
They used a standard NEO head and said a lot more could be done if the head had have been flowed to accommodate the larger displacement.
  • 7 months later...
True 3.2? does litre actually matter or stroke? When is the point where longer stroke stops making power?
and creates less?
Spool 3.2 stroke 91mm
86mm bore 3.17
86.5mm bore = 3.2
87mm bore = 3.24
Nitto 3.2 stroke 90mm
86mm bore = 3.14L
86.5mm bore = 3.17L
87mm bore = 3.21L
I personally think these cranks are similar as in the rips main caps and cradle and the spools version not long after
but just ask yourself, why is something cheap? What did they cut out? Was it just to make it sell easier? Or was there something that just wasn't needed?
  • 2 months later...
I think Rips latest engine in the Stagea will be revving at least 9000 but he is being a bit cagy about the actual size. I would guess its a 3.2 although he could be experimenting with something bigger.
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
