Guest Robo's
I just spent 2 hours on the dyno and finished up with 215rwkw on 13psi with the standard turbo on a Dyno Dynamics dyno run in Shootout mode. This is previously up from 187rwkw, but with the inclusion of the INTERCOOLERGUYS fmic and an exhaust cam gear, it made an extra 28rwkw. Im a happy man. Power is much stronger, especially top end.
Overall i had 16 runs on the dyno, walking in with 210-213rwkw but with a few missfires. I tried to tune out with the SAFC but to no avail. I wound down the boost to 9-10psi and was pushing around 198-200, with a nice steady climb with no missfires. So we figured, how do i run a nice clean run with higher boost, but with no missfires. I believed the extra boost was blowing out the spark. So i pulled out the plugs and gapped them from 0.8 to 0.7. Immediately at high boost there where no missfires and was getting 215rwkw on 13.3psi. Boosted it upto 14.5psi and it made 216rwkw, but midrange was lacking, so decided too back it off.
The intercooler looks great and fitted without too many dramas. Not once did the intercooler get hot during the 16 runs. A pleasure to have such a nice intercooler fitted and the performance is just great.
https://www.sau.com.au/forums/topic/38849-r33-fmic-results-215rwkw/
  • Replies 46
Holly crap you are running 13psi on the standard turbo? That sould last a few weeks at best :P I'm impressed that with the standard turbo you made 200rwkw's with 10psi!!! That seems very odd, I have a good hi-flow turbo and it is making 223rwkw's on 14psi and I have all the right gear with the exception of cam gears! Anyway stick the chart up when you have a chance.
Stop kidding yourself.
Robo's, that's an awesome result, mate. Well done! What plugs are you using, who is your tuner and how much was the cam gear/what type is it?
Adrian
Guest Robo's
Adrian
Im using Bosch Copper plugs 7 something code, maybe platnums might be better at higher boost, i dont know. Im the tuner, SAFC's aint the hardest to tune. Cam gear was from Ice performance, nothing special, just a modded standard unit, doesnt even have degrees on it, we had to try and work it out by eye.
May I suggest some BCPR7ES-11 gapped to 0.7 - 0.8mm for your next set. Leave the platinums to the people with more money than sense. :P
Very good result. Would be interested to see the dyno chart before and after to see whether you lost any power early on or through the midrange.
Adrian
Then you have the right plugs :cheers:
lol...
I've been racing on 1.0bar plus the nitrous for 3 months and 1.0bar for the year before that. The point is, there is NO hard and fast rule regarding when a std ceramic wheel turbo will fail. Just guidelines.
Adrian
shootout mode tries to make up for different losses on the dyno ...
the good tuners i know of don't use it
MSPEC - Ben doesn't use shootout mode, our dynos are non beefed up etc..
my 270kw would be closer to 300 on shootout mode...
dont know where u got dreamer mode from. Shoot out mode is shoot out mode, normal mode is normal mode, aslong as u say which mode ur hp/kw figure was achieved in then theres no dramas really, people understand. Im with 2rismo on the turbo issue. Many people say different things. Ive been running 13psi on my standard r33 gtst turbo for over 10 months now with no ceramic wheel trouble(knock on wood). Any way that dyno result is very good matey. Congratulations there, the car did well.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
