A while after I had my clutch pedal adjusted it started making some scraping sounds (best way I can describe it) that went away and came back a few days ago. So I'm pretty sure it was caused by too much pressure on the throw out bearings and I read that all I had to do was shorten the clutch pedal. After trying this and going for a drive eventually my clutch starts making loud eerie screeching sounds, engaged and disengaged and now I'm to scared to drive home. Help!
https://www.sau.com.au/forums/topic/388535-help-my-clutch/
  • Replies 45
What kind of clutch?
How old is it? or how much wear do you reckon its got?
Did you ever have it replaced? if so what was done?
I got a brass button clutch (it sux) and its sometimes noisy when i slip it. (grindy whine sound).
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193070
Im pretty much clueless with the history of my car. So its a throwout bearing problem, but I've been told to replace the whole clutch which I doubt I can afford. Do you know any decent clutch kits for a good price? I dont need anything fancy and clutches are beyond me
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193177
If it's the throw out bearing, I wouldn't think the whole clutch needs to be replaced. While it's apart though, it would be recommended to do anyway depending on a few things like wear, power output, prospective future modifications etc. Just don't let someone upsell you something you don't need lol
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193615
The first guy I called today told me to replace the clutch, something like 'because the gearbox has to come out anyway'. Not exactly helpful. Do you know any good places that can give me a good verdict on whether I have to replace the whole clutch or just the bearing?
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193719
what the hells an esp?
hahah do you know their details?
6244 9999, they're in QBN on Gilmore Road (just off Canberra Ave). It's where I had all my engine work done.
To be honest, the "because gearbox is out" is semi-logical. Labour for most general workshops on a gearbox removal and install is kinda steep, so if you're only running a standard clutch or if it's getting warn out, it really is a reason to do it now to save the couple of hundred dollars labour having to remove the gearbox next time when it DOES die in the ass
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194012
Exedy triple plate is what I'm running it's good and stiff
He's running a stock N/A, utter overkill and he doesn't need it stiff and hard, just a normal clutch feel.
Any of the heavy duty organic clutches should be fine. Jim berry clutch's are also very good as he cutom makes it to what you need, but again over kill for what you need. Exedy will be fine, don;t get sucked into the button plate, no need for a N/A.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194105
Noo.. thats the kind of thing ive got.
Its no good, i dont know why people would fit a clutch that doesent slip properly.
I didnt fit mine it was on the car.
See on just jap the pbr oem replacement, it has a circular friction plate. Like that but get the heavy duty one, its like the standard one just a bit stronger.... perfect.
Dunno who makes one for you.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194179
http://justjap.com/store/product.php?productid=17236&cat=522&page=1
that one? out of stock
seems like nothing has worked out for me at all this week
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194300
I might be able to take a look on Saturday/Sunday.
BTW, RB20/25/30 clutches are all the same (except maybe the 30ET). I don't know why manufacturers list different part numbers.
You would most likely only want a organic face, I don't think they come in a puck configuration. I'm sure I heard ceramic faces should avoid slipping or they will be not useable and can not be recovered.
Troy is right, if the clutch is in good condition, why waste money buying another clutch. Just buy another bearing, if the mechanics say you need a new one (after inspection) you can get exceedy kits locally and they should be able to get trade price.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194694
When the gearbox comes off you can see how thick the friction plate is (how much is left like brake pads).
Even if there is an inspection hole you probably cant see how much is left,
excl.gif BUT if you can see it you will be able to make a decision whether to buy a new clutch before the box comes off, heaps better. So try hard to look. Its worth it.
Putting it in yourself is difficult because you gotta lift the car high and the box is heavy and you need a clutch aligning tool (gearbox input shaft)
I love to DIY but this job is a pain and if you need the flywheel machined etc... too much hassle, maybe you should get a shop to do the work AND get the clutch and all that.
Its just gunna cost and your gunna have to pay.
PS: go over your adjustment one more time and really make sure its right.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6195389
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
