A while after I had my clutch pedal adjusted it started making some scraping sounds (best way I can describe it) that went away and came back a few days ago. So I'm pretty sure it was caused by too much pressure on the throw out bearings and I read that all I had to do was shorten the clutch pedal. After trying this and going for a drive eventually my clutch starts making loud eerie screeching sounds, engaged and disengaged and now I'm to scared to drive home. Help!
https://www.sau.com.au/forums/topic/388535-help-my-clutch/
  • Replies 45
What kind of clutch?
How old is it? or how much wear do you reckon its got?
Did you ever have it replaced? if so what was done?
I got a brass button clutch (it sux) and its sometimes noisy when i slip it. (grindy whine sound).
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193070
Im pretty much clueless with the history of my car. So its a throwout bearing problem, but I've been told to replace the whole clutch which I doubt I can afford. Do you know any decent clutch kits for a good price? I dont need anything fancy and clutches are beyond me
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193177
If it's the throw out bearing, I wouldn't think the whole clutch needs to be replaced. While it's apart though, it would be recommended to do anyway depending on a few things like wear, power output, prospective future modifications etc. Just don't let someone upsell you something you don't need lol
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193615
The first guy I called today told me to replace the clutch, something like 'because the gearbox has to come out anyway'. Not exactly helpful. Do you know any good places that can give me a good verdict on whether I have to replace the whole clutch or just the bearing?
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6193719
what the hells an esp?
hahah do you know their details?
6244 9999, they're in QBN on Gilmore Road (just off Canberra Ave). It's where I had all my engine work done.
To be honest, the "because gearbox is out" is semi-logical. Labour for most general workshops on a gearbox removal and install is kinda steep, so if you're only running a standard clutch or if it's getting warn out, it really is a reason to do it now to save the couple of hundred dollars labour having to remove the gearbox next time when it DOES die in the ass
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194012
Exedy triple plate is what I'm running it's good and stiff
He's running a stock N/A, utter overkill and he doesn't need it stiff and hard, just a normal clutch feel.
Any of the heavy duty organic clutches should be fine. Jim berry clutch's are also very good as he cutom makes it to what you need, but again over kill for what you need. Exedy will be fine, don;t get sucked into the button plate, no need for a N/A.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194105
Noo.. thats the kind of thing ive got.
Its no good, i dont know why people would fit a clutch that doesent slip properly.
I didnt fit mine it was on the car.
See on just jap the pbr oem replacement, it has a circular friction plate. Like that but get the heavy duty one, its like the standard one just a bit stronger.... perfect.
Dunno who makes one for you.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194179
http://justjap.com/store/product.php?productid=17236&cat=522&page=1
that one? out of stock
seems like nothing has worked out for me at all this week
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194300
I might be able to take a look on Saturday/Sunday.
BTW, RB20/25/30 clutches are all the same (except maybe the 30ET). I don't know why manufacturers list different part numbers.
You would most likely only want a organic face, I don't think they come in a puck configuration. I'm sure I heard ceramic faces should avoid slipping or they will be not useable and can not be recovered.
Troy is right, if the clutch is in good condition, why waste money buying another clutch. Just buy another bearing, if the mechanics say you need a new one (after inspection) you can get exceedy kits locally and they should be able to get trade price.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6194694
When the gearbox comes off you can see how thick the friction plate is (how much is left like brake pads).
Even if there is an inspection hole you probably cant see how much is left,
excl.gif BUT if you can see it you will be able to make a decision whether to buy a new clutch before the box comes off, heaps better. So try hard to look. Its worth it.
Putting it in yourself is difficult because you gotta lift the car high and the box is heavy and you need a clutch aligning tool (gearbox input shaft)
I love to DIY but this job is a pain and if you need the flywheel machined etc... too much hassle, maybe you should get a shop to do the work AND get the clutch and all that.
Its just gunna cost and your gunna have to pay.
PS: go over your adjustment one more time and really make sure its right.
https://www.sau.com.au/forums/topic/388535-help-my-clutch/#findComment-6195389
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
