Hey guys,
Thought I would post this here since it's had a lot of attention from this forum.
Goldray Energy / GT Auto / HKS R35 GTR for sale.
This car value is over $300,000. Not including tuning time. Motor has done about 500KMS.
ASKING PRICE $147,000
Below is mod list. Please note. The car has also had plenty of dyno tunning time. Car comes with Bride carbon seat/fibre glass passenger seat, trailer, camera system + 3 sets of 18" racing wheels.
Colour is Dry Carbon
HKS GT 800 Turbine kit
HI Octane Performance Coating dump pipe and turbo housings
HKS PISTONS
HKS Rods
HKS Head gasket system
HKS Camshafts
HKS F-Con V-Pro
HKS Valcon Controller
HKS EVC Boost controller
HKS GT2 Wastegate x2
2000cc Injectors(E85)
2000hp Magna Fuel Pump
Motec Sports Dashlogger
Custom Fuel Cell
PWR Light weight Intercooler(WRC & BTCC)
PWR Light weight Radiator(Nascar Spec)
PWR Light weight Oil cooler(F1 Spec)
PWR transmission cooler(F1 Spec)
PWR Diff cooler(F1 Spec)
PPG 6speed upgrade transmission
Willall Racing Kevlar clutch packs
Upgraded Front and Rear LSD
HKS Hypermax 3 suspension with custom valving/Spring rates
Hi Octane Front Camber Arms
Sunline Adjustable Rear Camber Arms
Sunline Adjustable Castor Arms
Sunline Adjustable Toe Arms
Project Mu SCR-Pro Rotors
Project Mu H16 Racing Pads
Volk Racing TE37 Super Lap Edition 18 x 11 +18 x 2 sets
Hankook 295/30/18 Z221 tyres
GT Auto Garage and A.D.E Chrome Moly Roll Cage FIA Approved
Aerodynamics by Andrew Brilliant (FXMD Aerodynamics)
Front Bonnet Fenders Bumper Headlight one piece Dry carbon
Rear Bumper Guards Boot one piece Dry Carbon
Dry Carbon Doors
Dry Carbon Roof
Dry Carbon Front lower splitter
Dual Rear Diffuser Dry Carbon
Dual Element Rear wing Dry Carbon(GT AUTO SPEC)
Custom Carbon Dash
Works Bell Paddle shifter RaptorII and Boss Kit
Bride Racing Seat
Willans Racing 5 point Harness
This car came 4th in Australia at 2011 World time attack and currently holds the lap racord at QLD raceways Clubman curcuit on radial tyres.
Nothing more to spend, ready to race!
Phone me:
Drew, 0458 979 373
https://www.sau.com.au/forums/topic/388656-1000hp-carbon-r35-gtr-moving-on/
Bargain!! for anyone who wants such a thing. this car is amazing in the flesh.
But...but but...why? 500km on it, its not even run in. why does everyone spend sooo much money on a car and never use them? be it a street car or race car. it confuses me.
bigger better project on the way?
  • 2 months later...
huge price drop. now 95k
Now comes with broken rear diff :)
(about 5k fix)
Athough, I just spent 5k on engine recondition.
I have also removed camera and 2 sets of wheels from sale.
So its now the car, trailer and 1 set of wheels of your choice (nismo lmgt4, or volk te37's - grey of blue)
This is a great price for an amazing car..
Here is footage of the run before diff went:
Edited by druzilla32
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
