Hey guys ive got up for sale my fully forged built 1000hp Rb26. Heres the list of the parts worth 22k+......
1000hp R33 Motor:
CP Pistons
Howard Rods
Head with mild ports
282 spec cams with retainers
ARP head and main studs
Ati balancer
Custom Valves
Custom springs
Jun oil pump
Trust sump with extension
Block has been specially prepped & cleaned
Crank has been prepped & fully balanced
Motor built by Matouk Performance in sydney, does not come with turbos or manifolds etc. just rocker cover to sump
Motor made 700-750rwhp with T51R with plenty more left in it!!
For any questions pm me or msg me on 0448868384..cheers
Selling for $8,000, which is alot less than it cost to build the motor. It has been only driven around 3000kms so still new.<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">
<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">Sorry guys i do not have the reciepts from the build..Call 0434778285 for proof of build.
https://www.sau.com.au/forums/topic/388663-fs-fully-forged-rb26-motor-8000/
is this motor at japanese motorsport? i was told its a 2.7 litre?? whats the deal with it? and was also told n1 oil pump??
yes it is at japanese motorsport, its a 2.6l mate and its not an n1 pump
Edited by scr33m
  • 3 weeks later...
  • 4 weeks later...
Engine is getting pulled apart within the next few weeks to get a proper list of the mods done to the engine because i don't have receipts for the build. So if you are interested let me know soon if you want the head or bottom end, full motor etc...cheers
  • 4 weeks later...
Confirming its 3000Km on it, im a little interested in the bottom end....
Would you be willing to show it with the sump and rod caps removed and head off to inspect the bores, bearings, crank journals and oil pump?
Over bore? Brand of bearings? Built loose or tight? Are the crank journals the factiry size or have they been machined down? 8.5 or 9 to 1 pistons? Standard CP gudgon pins or heavier ones?
Some high quality pictures may make it worth looking further into, if i like what i see id come over to inspect it.
Edited by GTRPSI
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
