NEW FOR SALE LIST: r32 parts and random car parts.
R32 GTS-T PARTS-
Standard front and rear spring $50
Standard front shocks with springs $50
R32 GTR FMIC with pipes for R32 GTS-T $300
3" turbo back exhaust includes 3" DRIFT dump pipe, 3" GKtech front pipe, Gutted Cat, 3" DRIFT Catback Exhaust with DRIFT cannon $600
2,1/2" catback exhaust with DRIFT cannon $100
Standard front pipe $20
Standard dump pipe $20
M-Spec side skirts $100
M-Spec rear pods $80
DRIFT pod filter $10
K+N panel air filter $10
DRIFT BOV with adapter plate for r32 $50
Standard BOV $20
OTHER PARTS -
POWER UP boost controller "T" $50
MOMO steering wheel one dark grey one black $50each
MSG me on 0431374737 for pictures, I live in Gisborne are.
Also have a r32 in the back yard so for any other parts just ask :)
https://www.sau.com.au/forums/topic/388770-car-parts-mostly-r32/
Hi would you be willing to remove and post one of the power steering lines to Wagga (2650)?
It would be the one that goes along the front of the crossmember then connects to the lower of the large bango bolts on the front steering rack and has a sensor in the middle of it( I can provide pics if needed)
Thanks
Vince
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
