if you were only racing yourself, there wouldn't be classes. And they'd only give each person their own times. :P
I only call them 'cheater slicks' because they're pretending to be a grooved tyre or semi when they really aren't. They're 98% of a slick.
Edited by hrd-hr30
Hmmmm, for those trying to compete for prizes it just could be important, I don't know, not me. Yeh and we all know that compared with targas sprints are small time, oh to be a big fish in a small pool.
:ermm: Why you felt the need for "targa" and "fish" references has me puzzled. I didn't realise you found me so abrasive. My apologies if I've somehow offended you Richard.
Well, in a sprint, would you agree that you really are only racing yourself? Or are we on a completely different page?
Sure, if there's someone you benchmark and would like to beat, then so be it. But I feel, to be handing out trophies for fastest 4, 6 and 8 cylinder cars on a sprint day I find completely pointless. It's pseudo competition and contrary to what a sprint day's mantra is, and that is non competetive timing.
To enter you need to pick a class, 25/30 with all the fruit puts me in SVD, yes there is a comp but Im no where near competitive, Ive only done 2 or 3 sprints that need legal street tyres to be in street class comp, (the SAU vs RENEW thingie)and even though the semis Ive used were street legal they said something about being to low with the UTQG and I was placed in club class.
All other sprints Ive done you could use whatever you want, unless it rains, then no slick till the track drys off.
Ive only been playing this game for a couple of years but dang its fun.
Last year I think I got about 10 points in the SSCC comp, LOL.
Geez, because you were so dismissive of cheating in sprints. For the millionth time, now there is an official competition with classes, rules and prizes. Ring a bell? Still keeping those beaut Lakeside laps you did on YouTube as a favourite though :P
It's important to remember that what Queenslanders call Sprints are quite different to southern states. Qld Sprints are traditionally non competetive times laps with cars in groups of similar pace for safety reasons.
Therefore, I see the two words "cheating" and "sprints" as an oxymoron.
And FWIW, my best time around Lakeside (that several of us here frequent), was achieved on R comps, not slicks. The slicks however, lasted longer, and were therefore more cost effective.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
