Did anyone else have this installed in their V36? It looks like my car has an extra TV tuner already piggy backed of the factory one. Its a panasonic tu-dtv30-2. I even got the instruction manual and remote for it (all in japanese).
I know theres fat chance of it working in Australia but thought id ask before i replace it with an Asuka unit.
If theres a slight chance, i will find a Japanese person and get them to try and auto-tune it for me and see if it picks anything up. (i tried but the menu's are all in jap and cant figure it out)
Also, if i do get an Asuka (which is highly likely). Will the video work while car is in motion or do i need a cable or something?
thanks
https://www.sau.com.au/forums/topic/388897-v36-another-tv-tuner-question/
thanks
I've got some Panasonic device installed in my v36 but I dont know what it is yet. I've got two thin black devices on both sides of my windshield and a sensor installed on my console obviously for some sort of remote that I dont have. i googled the part number of of those devices and it came up with some Jap page and appeared to be talking about digital antennas.
Its most likely NTSC formart anyway so you wont be able just to "tune" it to PAL. There will be some sort of conversion needed.
AFAIK, the v36 comes with a analogue tuner, which is now useless in japan, because they've switched off all the analogue transmissions and have gone to digital. The previous owner must've installed a digital tuner. Problem is, the tuners aren't compatible in Australia. AU uses DVB-T and japan uses isdb-t. You'll have to replace the whole unit to get it to work
Sounds like you may have the same unit as mine. Maybe nissan dealers in Japan offered customers a replacement digital tuner after the analogue stations were switched off.
Anyway sounds like its not going to work so im going to get new tuner soon. At least it should be a pretty easy install since some of the wiring is ready to go.
Yeah I thought thats where it would be but coulnt see anything. I dont know where else they would hide this thing.
Maybe its on either side of the spare wheel under the plastic.. Or its possible they took it out?
Does your I/R remote sensor have a little red power light on it when the cars on?
Yes red light is on, Im going to check again
Man I can't find this thing, checked under the plastics in the boot, all I found was a beige coloured box that had a Nissan logo on it but I dont think it has anything to do with the Panasonic tuner. Not in the glove box. Where else could they put it?
1327388805[/url]' post='6202358']
Follow the cable trail from the antennas..
I ordered the zylux thing today from jb Hifi.. Got it for $430 in the end. Found out there cost price is $349 so if you feel like bargaining you could probably pick it up for under 400..
Picked it up today. They sent me the wrong one! Its the non high definition model. :(
Pissed off because i cant be bothered waiting another week for them to send the right one. Also the price is apparently the same so cant get a credit for the difference and keep the SD one.
I'll probably just install this one. Just means i wont have the HD channels.
I ended up installing the new tuner yesterday. Took a few pics along the way.
used the same mounting bracket from the panasonic.
Antennas are mounted at the top of the back and front windows just under the roof lining so you cant even see them.
Everything works great, even "drive in motion" works. All i did was gound the handbrake cable. I thought it was going to be a quick install because I could use the existing cables from the old tuner. It still took a good 4 hours by the time i removed the old antennas and everything. My back is not a happy chappy!
Edited by projectx
so good to see things in english.
So its operated from the remote, which makes the steering wheel and dash controls obsolete?
Yep, but i only plan to use the tuner for TV or movies. You can still use the volume up/down on the steering wheel, but to change channels you will need the remote.
For music i want to use the music box anyway.
Would be cool to get the touch screen working for the tuner! Im guessing thats either not easy or impossible. anyone know?
Edited by projectx
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
