Coasting along at 60km/h on my way to work this morning, my car (R34GTT) starting running really rough and slowly dies to a stall. Now, this happened only a few weeks ago and turned out my battery was shagged - now have a new one and same thing basically has happened again at pretty much the same intersection. I knew it wasn't the battery as the car was turning over fine but there was a weird squeal from time to time. I let it sit for a bit trying to start it every few minutes - after about 10 mins it starts and I putt off to work.
Only have basic mods: 3.5in turbo back, FMIC, pod filter and I have had my 100k service done (around 80k's on the car) but I don't think the coil packs have been done. I know these are prone to fail but just want to see if this issue could be anything else? Do you think I will be able to make it home this afternoon?!
https://www.sau.com.au/forums/topic/389209-please-confirm-gurus/
I wouldn't be so quick to assume coilpacks, in fact it could be something smaller like the AFM or CAS. If you think coilpacks though I think you should take them out, check for burn marks on them and if so, wrap some electrical tape around them and see if this changes anything.
well I am only speculating as it seems to be a common prob. To those that have had coilpacks fail on them - what are the symptoms?
When mine failed it was just one that failed and you get a permanent missfire as one coilpack shit itself... It happened on startup and i just replaced them on the spot with Splitfires.... Not the same as what you are describing?
BTW - Anthony had some splitfires for sale dirt cheap in the FS section (Guilt_toy)
Hmm, no definitely not what's happening to me mate. Spoke to my mechanic and he thinks AFM or one of the sensors, he is going to check for fault codes tomorrow morning. Better not be something major as I have just dropped a load getting the 100k service done early!
bit of an update - my mechanic didn't find any fault codes or anything abnormal, however suspected (along with a few others) that the symptoms suggested AFM or CAS. The car stalled on me again today but instead of just dying out of the blue it started shuddering under acceleration first then eventually slowed to a complete stall.
A mate flushed the AFM out with cleaner and also cleaned out the pod etc - seemed to be a bit of rubbish in there along with a half cracked AFM plug. Taped the plug up and I took it for a half hour drive with no issues so far....HOPING that's all it was but probs not that lucky :closedeyes: so brings me to my next questions - which AFM's fit R34? can I go straight to a Z32 or should I just go for a brand new OEM? cheers
Z32 will need a re-tune, Clint :)
Physically the same size as the RB25 AFM but with more resolution.
Perfect opportunity to get the car Nistuned although I think you'd struggle to find a mob competent enough to do it in Twmba. :P
I believe you could try asking your mates with R33s if they can swap AFMs with you for a bit to see if the problem goes away.
I'm not sure if RB25 Green (R33 series1) and Pink (R33 series2 and R34 Neo) labelled AFMs are the same but I'm confident the pink ones from the R33 are exactly the same as the R34.
Could also be the plug as you mentioned...be it cracked / loose / etc..
At your service.
Trolling SAU since 2007 ;)
Yea, try to get another AFM/plug to test. If problem re-emerges, you can move onto something else (think you already know this haha)
I would offer but my AFM/CAS/Coils/whateveryouneed does you no good :P
  • 3 weeks later...
May be completely unrelated. May be a lil bit related... I had a camry once. It had a dodgy voltage regulator in the alternator. This caused the alternator to slowly deny charge to the car. The battery light was always on (thought it wa faulty, lol). This then lead to a loss of power on the highway... spluttering... and finally, a stuck car. Battery was dead. as it wasn't charged.
But since you didn't mention a battery light, or anything of the sort. I'll assume it's not that. But have you ran a multi over your car yet? Just for kicks?
Yeah my mechanic speculated CAS originally but wouldn't that make it run dodgy more consistently or would it only be an issue for hot starts? It seems to be fairly erratic atm. Sometimes it will hot start fine, sometimes it will have a slight hesitation, other times I will have to crank it for a couple of minutes - let it sit for a few minutes - then try again.
Dion - haven't seen any battery lights etc, and I put a new batt in only a month or 2 ago so hopefully not an issue. Running a multimeter over it sounds like a good idea - any specific areas I should check?
Just to elaborate a bit. My car was hard to start hot and would itermittantly miss at times through out the rev range.
Also at times i would take off from the lights and the car would bog and crawl for 50 meters then take off.
I replaced the Afm (the old one was clean with good solder on the pins) This fixed the missfire and bogging down issue.
Was still hard to start and worse when hot.
I Bought a new CAS and fitted that, now starts perfect.
Pulled the old one apart to inspect. There was wear in the keyway, when spinning the shaft you could feel the rumble in the bearings and it was full of dust.
May be of some help
May be of some help
yeah mate, I was having the bogging down issue too until I cleaned my AFM.
Not sure if this helps diagnose my issue further, but I notice the car seems to pop a lot more more between gear changes - especially when I am under it. I may just have to bite the bullet and get a new CAS, is it worth trying a second handy?
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
