Hey mate, i had the same trouble when i brought my R33 from adelaide and coverted to NSW rego. Any place that can do blueslips (If your NSW) Can ring the RTA and request all the information you req. Apparently they do this anyway due to some dodgy importers importing to many cars. And if your car is one of them it will never get re registered. Hope this helps.
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6203744
The agency that holds the import papers is the federal Department of Infrastructure and Transport, used to be called DOTARS.
Their details are here:
http://www.infrastructure.gov.au/utilities/contact.aspx
THey will have the import approvals on file, my mechanic recently needed a copy of my Stageas ones
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6204623
http://www.infrastru...es/contact.aspx
Awesome, thanks Duncan.
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6204857
Great info Duncan.......
Do they happily supply people with the respective documents or do you have to go through the Freedom Of Information crap?
Do they keep the compliancing info too? If not how would you be able to get a copy of that?
Thanks,
Bob.
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6205358
Would also like to know.
Id love a copy, just to add to the folder.
Ok so I called the number on the website, they said to email [email protected] and someone will contact you in a day or so. That email address is not on the page so I'd say just email that, we'll see how long this takes.
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6206019
Bob those guys are unlikely to give out import papers for ADM cars, both cars I have papers for were SEVS (or the previous scheme) low volume imports
Hi Duncan........ I wasn't thinking about my car I was thinking about a JDM that I will eventually buy.
It would be nice to have as part of its history as would the compliancing documents. Do you think they would issue that for a JDM import?
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6209405
Ok so this was pretty much a bust. They send you a letter confirming that the approval for import of your vehicle on the date it was granted. Due to "privacy" you can't get anything more than that it seems, so it's kinda useless except to aid in registration.
https://www.sau.com.au/forums/topic/389333-import-papers/#findComment-6209877
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
