Need these parts gone asap located in the MULGRAVE, VIC area contact me on 0431336612 SMS or PM me for Pictures
ALL ITEMS ARE ONO
RB30E Engine Loom $15ono
Was from the 2nd engine i had with my 1st R31. Worked well before i took it from the donor car.
R31 Intake Piping $10ono
No Hole Still Good
R31 Centre Console $5ono
Lame looking center consoles the R31 Executives had. Poo Brown Colour
[glow=red,2,300]R31 S3 Auto ECU $5worked before i took it out of my old car[/glow] SOLD
Adjustable GT Wing w/brake light and loom $80ono
Bought this off scoot3r42 then never used it would look good on a r31
RB30E Standard Exhaust Manifold $20ono
Done about 200,000km.
R31 Mudflaps $20ono
Needs a Cleans both front & Rear. the rear ones have nissan in white enamel
R31 White Gauge Faces $55ono
had it in the car for one day then put in back in the box (bought it off Sinbadscott)
C34 Stagea S1 gauge cluster $150ono
My old gauge cluster from my Stagea with 106,000km.
M35 Stagea Washer bottle $80ono
no holes or anything. 2nd hand got it for $100 so ill sell it for $80
TRACKPRO Central Locking Kit $50ono
Its Universal so it goes on any car. Fits on all 4 doors. Never been used. Still in box
VH Commodore L + R front corner indicators (Orange) $15 each - $20 both ono
Been sitting in a box for 5 years. No cracks. In good condition. Just needs to be sealed again
VN/Lexcen Clear Tail Lights, Sedan $70ono
Need a clean in good nick
SPECO volt gauge $40ono
Never Been Used
Sports Steering Wheel (looks like a R31 GTS1 & 2) $60ono
Only put it on my R31 for one day then took it off. Perfect Condition. Like New.
Sidchrome 31 Piece Metric & A/F Socket Set 1/2" Square Drive $70ono
Only used them a few times great condition
Sidchrome 23 Piece Metric & A/F Socket Set 1/4" Square Drive $50ono
Kinchrome 8 Piece + & - Screw Driver Set $40ono
Used Them A Couple Of times Great Condition
Edited by CHASRS4
Prices have gone down for this weekend only pm me or sms me for new prices (Wont let me edit stuff)
Prices will go back to normal prices monday (30-1-2012)<br>
Edited by CHASRS4
