  • Replies 68
Well Im going to add my two bobs worth...
I have got a PST carbon shaft in my GTR R34 it is the best there is.... you get what you pay for.. you want to go lighter then depending on power you will be buying another one as it will break...
I bought a ACPT shaft and I broke it in a week, it was shit, then they sent me another one as replacement it was suppose to be the 1200hp one, I could not even drive the car above 40 klms/Hr the vibrations were that bad, I rang them they said it had been balanced the service was piss poor and I was pissed off, so I sent it to a engineering shop to get rebalanced. So another $600 for the rebalance and it was ok... I Will never by another one from ACPT they make them for trust, nismo and all the other Jap brands.. they are crap.
By this time I put a Holinger in my car so I spoke to PST drive shaft in the US they custom made one and it is awesome.. good to talk to and the price was very reasonable, it will be better now the Dollar is $1.06 The gearbox will break before the shaft will.
Dont pm me asking stupid questions on the weight, cost or where do you get it, do your research as I did.
Such a helpful guy you are
:thumbsup:
Trent I also have a PST carbon shaft in my car and have fitted one to another car that you would know fairly well. Sold one to another guy and have never had a complaint from him. I also have another one here waiting to be fitted to another car currently in the build.I would recomend them as they were good to deal with and where reasonably priced individually but are flexible on price if you organize a group buy. Give me a call if you want contact details.
Just spoke with Mark at PST (sorry Dazmo, too early to call you).
Price is US$1099 so nearer AU$1025 with the currency around 1.08.
3 1/4" carbon tube which includes joints on each end, ready to bolt in to your car. Weighs around 12 lbs = 5.4kg.
rated to 1000 ft lbs of torque (1355 nm). Said he could make one rated to 1350 if need be for an extra couple of hundred bucks.
shipping likely to be around $150 mark.
Edit:
Torqline shaft failure load in excess of 4000nm.
I know which one i want. just need to find the extra $$$.
Edited by tk80
Edit:
I know which one i want. just need to find the extra $$.
My last dyno graph shows 1012.4 FtLb so I'm out for the PST shaft.
If you go Torqline let me know.....
Edit:
Thats awesome for the price. Will have to look into getting one for the gts-t.
Edit:
4000Nm... using same / comparable testing method?? that's a shitload more. Will be interested to see how they stand up to the torque from the higher-powered RBs, whichever route you decide to take.
4000Nm "failure load" is different from 1350Nm torque rating. 4000Nm is the breaking point of the Torqline, 1350Nm is the safe output for use of the PST.
What's the weight difference between the carbon and aluminum ones?
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
