I need some advice on which oil to use for my R33 GTR.
The car is stock standard apart from the exhaust and I currently use Motul 8100 X-Cess 5w40. http://www.motul.com/nz/en/products/52
It costs $100 NZD here for 5L of X-Cess.
I was wondering if the Royal Purple HPS 10w40 http://royalpurple.com/motor-oil-hps.html would be a good alternative instead of the Motul because I could get 5L for $60 NZD rather then $100 NZD for the Motul oil.
  • Replies 42
I've always waited till Repco do their motul 20% off and grabbed X-Cess for $65 (AUD) for 5L (I haven't done this in awhile as I've still got plenty of GW Suigi S 6000 to use up). From what I can tell about that particular RP product that it might just be a semi-synth (comparable to Motul 4100 Turbolight).. as far as I know only the RP XPR racing oil is fully synthetic (which would be comparable to X-Cess).
That being said there is absolutely nothing wrong with a good semi-synth on a street-only driven skyline, as long as it's changed every 6 months or 5000km.
Another +1 for 8100 X-Cess. Been using it for a few years now, changed to Castrol Edge when I couldnt find any 8100 around where I live but found my oil pressure was to high on cold starts, 8100 is much better :)
Im sure either will be fine.. i currently use RP
but looking for a cheaper alternative since i will be overfilling my sump to 6L, ill now need to buy another bottle
Does Motul come in 1L bottles?
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
