Selling my current setup..
Mr.Turbo built turbo.. Based on a garrett 3071r using a fj20 .63 rear housing,welded up internal gate.
Modified standard exhaust manifold for external gate.
38mm turbosmart gate,with screamer pipe.
Highflowed side feed injectors,550cc done by PJ.
Z32 airflow meter brought from JustJap.
Power FC with hand controller tuned for this setup.
Custom made dump and front pipe.
Modified intercooler pipe to suit turbo outlet.
Car made 243kw at the wheels with boost starting at 18psi and dropping to 15psi...
Very safe tune as it was getting drifted a lot.
With new boost controller holding 18psi,it was good for just over 250kw..
Very responsive setup,seeing full boost at 3700rpm
Kit has been on the car for 1.5 years now,half of which was just sitting in the shed because i crashed it,.
Reason for selling is engine blew a head gasket and looking to up grade everything at once.
Looking to sell everything together as it will be a BOLT ON KIT, I will supply everything,oil lines,water lines,dump pipe,everything i had to change to put setup on will be sold in this kit.
$2870 for everything
Contact me via PM on here or msg me on 0401865224
https://www.sau.com.au/forums/topic/390386-rb25-turbo-kit/
Injectors are high flowed JECS... Not nismo
jet2nv : The dump pipe is to suit this turbo,or any other turbo using an fj20 rear housing,has a different bolt pattern to any other turbo iv'e seen..
https://www.sau.com.au/forums/topic/390386-rb25-turbo-kit/#findComment-6217348
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
