came here to add to a feb thread and found there wasnt one.
hope its not out of line to kick one off now?
heres 2 similar shots i took with my tiny instant camera on the way home from the gym
second one is framed better or?
in the shakespeare hotel
and on redfern st, if only i could have kept it straight and had a decent lense.
was in a hurry as i didnt want to be weird stalky camera guy for too long.
https://www.sau.com.au/forums/topic/390413-febuarary-2012/
  • Replies 72
Out of your first 2, I like the 2nd, I think because there isn't as much to try and focus on.
yeah i thought so too, nice to hear my instincts werent too off.
All those shots are beautiful fongy but that one is the most interesting, slight tilt shift? so much depth..the car practically pops out of the shot!
https://www.sau.com.au/forums/topic/390413-febuarary-2012/#findComment-6218913
Thankyou! :)
Yep slight tilt shift effect for the background to get a little more 'pop' :D
Did you take these? They're very good
I did :)
http://www.facebook.com/formnfunction
i re-post some stuff from stance nation,etc on the wall from time to time, but the rest is my work.
Edited by fongy8000
https://www.sau.com.au/forums/topic/390413-febuarary-2012/#findComment-6220827
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
