a miss is like a hesitation in the acceleration, pinging is very hard to hear....you see experienced dyno operators with earphones to the engine block to detect it. Some ppl say they can hear pinging...some say you can't....
As I posted earlier I think its much more likely you just have some sort of missfire.
I had a friend who knew about cars come round, and I got him to passenger as I 'spiritedely' drove it.
I gave it quite a bootful, and it went as smooth as a baby's bottom and still boosted to around 0.7 Bar. No noise nothing, so I'm stumped now, it ran better then ever and knew straight away it didnt feel like my line when it was stock.
Perhaps it was some other noise which cleared out.... i'm just glad it doesnt make the noise any more :mad:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
