Hi guys,
Last night i went out for a run in the 32gtr Launched in first. then boosted up to 180,
as soon as i let off a loud ticking/pinging sound was coming out from the engine,
I turned it off at a mates and let it cool down, started back up but only made the sound when free reving above 3000 RPM
Took off to take it home and under load it wouldnt make the sound or backing off, only when in between load and off load if that makes sense (cruising), by the time i got home the ticking/knocking had worsened and was doing it at idle.
any ideas? i'h hoping its not a big end as it sound like is coming from the top? (car still drives/boosts and revs fine.
Regards Jimmi
https://www.sau.com.au/forums/topic/390568-rb26-nasty-knocking/
It could be anything. I'm going to say noisy lifters. If you had a big end spun, you would know. It would sound more like a hammer on your block. If its a light tap, knocking sound, its probably head related. I'd put some new oil in it and see what it does. If the problem gets worse, louder, constant etc it may well and truly be a big end or some other thing at the bottom.
I experienced the exact same sound about 4 weeks ago. Turns out i spun no.5 bearing. Fairly similar situation too, mine was caused by oil starvation.. Not good.
Hopefully you have better luck than i did. Take it to a mechanic, or get one to come to you..
Best of luck mate.
id say the luanch then full throttle all the way to 180 is pretty much a give away that the cause of the problem was oil starvation
What i wanna know is
-what power are u running?
-what engine mods do u have and do u run a baffle or modified sump?
-do you overfill your sump?
Hi guys,
Car is a Late 1993,
Power FC
Twin Nismo t28's
Tune
Standard Injectors,
Running 17psi At the time
Standard Sump not overfilled.
Air Temp at the time roughly 18-20 C
Roughly 355rwhp
Oh and 72,000kms,
Edited by GTRSOL
Did i say that the head flooded with oil?
how would the head flood with oil if the oil pick up isnt picking any up
If you are pulling hard G's for an exteneded period of time, which is entirly possible in a GTR that performs a hard launch then is full throttle all the way to 180kms, then you can starve the engine of oil as the oil is not near the pick up...
insane?.. i think not
I wasn't going against what you said, I just assumed you were probably implying that any useable oil would have been flooded into the head! Ive read that it doesn't take very long at all on some high rpm to fill the head up with pretty much all useable oil in the sump.
Pulling enough G's and maintaining that in a straight line to starve the engine of oil.... that is crazy shit insane! Its amazing to see these oil control issues evident in skylines. They are all very possible situations and you would think Nissan would have thought of ways to prevent this stuff from happening.
Also those KM readings, 72000km.......................................................................................................................... nah.
Is it a bad thing to overfill your sump? It takes me some good time to fill up my car and get it exactly on the right mark on the dip stick. I over filled it once and I let some oil out because I read it can do bad things but I didn't see how or why...
Edited by SargeRX8
So, if the oil is not in the sump, where is it?
How the could the head flood with oil? I would have though it was obvious that this would happen before the sump is empty.
sorry to hear mate
so is it a good idea to overfill 26's with oil??
Yes. For track work, many fill the the bottom of the top bump on the dipstick. So about a cm above the full of the hatched area.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
