Hey guys, There's a air hose missing, Not sure where it leads connects.
Car is running rough and hunting through the rev range on idle so would like to fix soon :)
It's the gold metal line as seen in the picture that is blowing air.
Edited by ItalianSupastar
https://www.sau.com.au/forums/topic/390839-missing-rb20-air-house-please-help/
that pipe should go to the blow off, somebody removed the blow off and blocked the pipe (as you can see with the 2 bolts holding a cover on it)
get a piece of HOSE and put a bolt in one end (so it seals it tight) and put the hose on that pipe.
it will fix it for you.
Haha mad spelling mistake by me FML!
Thanks for the quick reply, Yeah the blow off valve is weird aswell :S Never seen anything like it!
Haha its a blank off plate the stock bov goes there as gtscott said get some vacume hose and put a bolt in it so it is blocked off or buy a stock bov
Wait a minute youve got a 32... show me some thing please, im having trouble finding where my outside sensor for ac goes, a lot of the front was missing when i bought it.
I can take any photos of any area on mine if you need for you might find more missing/dodgy bits as you just bought the car.
The ambient air temp sensor for the climate control goes pretty much where you circled. On a factory R32 it is pressed into a hole on the bonnet catch support (the vertical strut of whicj that goes down in front of the radiator). When you have a front mount installed, assuming that the vertical strut is not butchered, then it's not smart to leave it down there as it gets hot air through the intercooler. So I just moved mine up to be behind the grille under the bonnet catch. Any combination of cable ties required is suifficient to mount it.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
