Heyas.
How much work is involved in fitting a pair of HKS 2540's to a stock 33 GTR engine? I thought it would just be getting underneath the car and start pulling off the exhaust and the rear turbo till you can get to them. One guy I took it too said he would have to remove a whole heap of shit, maybe even one of the engine mounts to tip the engine to one side to get to them.
He does know his stuff and I trust him, just he has never done any work on a GTR before, also whats the max I should be paying to get them fitted, He quoted around $400, does this sound fair?
https://www.sau.com.au/forums/topic/39124-fitting-lowmount-turbs-to-a-gtr/
Hi,
I have a 32 GTR and I took the turbo's off my car by myself at home. I'm definitely not a mechanic at all, but I did it. Took 2 nights to do it, about 4 or so hrs each night. I just unbolted whatever i thought needed unbolting ;)
Front pipes where first to come off along with all intake and associated intercooler piping. No idea what was the 'right' order to do things or not, i then unbolted the the coolant/oil lines from the front turbo, unbolted the turbo off the exh manifold, undid the 6 bolts of the exh manifold to block and managed to get enough leverage to pull turbo out with manifold still just attached on studs to block. After turbo and exh. manifold came out separately you can start doing it all again with rear turbo. This ones a little harder, less room etc. I left the manifold attached to the turbo and a little painfully I pulled out all together. undoing the necessary oil and coolant lines were damn annoying (hard to un do!).
I had a quote to pull turbo's off, then put back on with all new HKS gaskets for around $850. So far its cost me nothing apart from the turbo rebuild/hi flow.
Once again, im not a mechanic, never been one :D Only had a basic socket set with a few little extras connection pieces.
Jono
Hi,
I have a 32 GTR and I took the turbo's off my car by myself at home. I'm definitely not a mechanic at all, but I did it. Took 2 nights to do it, about 4 or so hrs each night. I just unbolted whatever i thought needed unbolting  :)
Once again, im not a mechanic, never been one :mad: Only had a basic socket set with a few little extras connection pieces.
Jono
How did you GTR go with the hi-flow turbos??? I'm thinking of hi-flowing mine...
should take someone whos done the job before about 8 hrs to 10hrs for a gtr lowmount turbo swap. so about 400 to 600 bucks..
if they havent done it before dont bother getting them to do it as you will pay for many more hours labour..
also some guys drop the engine and gearbox out and then its very fast to do the turbo swap.. but price would be close as the above way,,,
cheers.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
