We have 19X10 +20 with 275 tyres, rear guard lips needed a trim, a narrower tyre would have been fine.
Rim lip sits dead flush with rear guards.
Edited by GTRPSI
I have seen 18 x 10 +12 all round and they sit flush, when lowered until no wheel arch gap.
No guard work needed.
They are an awesome fitment.
Recently a friend of mine just lowered his GTR and he has 18 x 10 +12.
I think 235 / 40 / 18 tyres on 18" would be slightly stretched.
