Hi everyone,
I want to upgrade the exhaust on my 97 model GTR, currently it only has a 3 inch pipe from CAT back into nismo rear muffler.
I find it drones a bit on the freeway which I hate. I want something that doesn't drone but once you hit boost the amazing sound of the RB26DETT comes to life.
Any recommendations from Turbo back?
Thanks
Engine is completely stock. I just don't want it to drone on the freeway, but still have some loudness about it.
budget: Any.
was thinking of upgrading the dump pipes, high flow cat then rest of the exhaust.
I've heard some GTRs and they sound awesome.
My friend that has a R32 GTR (everything stock on engine bar FMIC) has a Fujitsubo 3 inch and sounds awesome. I think dumps are Tomei. The rest is Fujitsubo.
Hi-flow cat, too. But in saying that.. I think HKS Superdragger sounds tough.
i just replaced my dump and cat with 3.5inch hiflow and now the exhaust sounds alot better, fujitsubo 3 1/2inch catback, same muffler but now its not that quiet anymore lol
mine might be up for sale soon
custom made 3.5" stainless steel from cat back with rear cannon muffler (3.5" id).
have a cat somewhere for it too. think it's a 3" cat that is flared to 3.5" to fit the rest of the system.
i think it sounds great but my front/pipes are not standard...nor is the engine.
What is this coming off of? I love the idea of a nice, light titanium system.. But the sound is a little... "tinny" for me. At least, the few that i have heard.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
