  • Replies 49
Black BLACK!
Haha. Gtr -> rwd, easy
Gtt-> gtr, so not worth the hassle.
And why do you personally not like awd? Or did you drive a evo and think "nah awd is not for me".
Gtr is a different type of awd. Just saying.
mate, dont get too worked up about the whole thing
without being too harsh on the OP, lets be 100% honest with our selves here, we ALL know that this guy IS NOT going too spend the money on converting his gt-t into a gtr look-a-like. Nor is he going to buy a r34 gtr, just to turn it rwd.
this is an internet based forum where ALOT of people say things they really dont mean.
Now i could be completely wrong, and OP has thousands and thousands of dollars spare to spend on modifying a 12 year old gt-t in such an extreme way, for no real apparent gain, then good luck.
GTR to rwd is easy enough, drop front driveshafts, hack front diff off sump, remove attessa computers etc and chuck in an RB25 box. But I don't see the point.
Have you driven an R and then come to the decision that you don't like the AWD or have you just gone, "Yep the GTT is rwd I like it" and not done any research into how the R actually handles.
I haven't driven a 34R but I have driven a 33R and whilst the 4wd and rwd feel completely different it is a great handling package. Feels a bit heavier in the front but it feels a lot more balanced and smooth. If you want your GT-T to run an rb26 then do that and save the coin on everything else. otherwise drive an R if you haven't already and see if you really do dislike the AWD as much as you think you do.
Another thing to consider, as well as the guards being pumped out and the suspension being mostly the same you will have to swap rear hubs from loop type suspension to fork type and LCA's etc are different to provide you with the added 20mm rear track. Front track however is the same.
soooooooooo yes, no, i need a black or white answer
I like this guy.
With such a great title, I was expecting a thread subtitle along the lines of "just ran over a homeless guy - should I call the cops?" or "I just caught my sister in bed with my mom"...very disappointed...
Ok great stuff here, and also, the money situation isnt a concern, also if i was to stick to the GT-t and i got all original GTR body kit, side skirts bonnet rear left and right quarter pannels front and rear bumper the lot, would it be a hassle to fit onto the gt-t, thank you for your patience people, i greatly appreciate it
I smell a troll..
I answered the question a few posts back with reference to a R32. same idea.
also if money is not a concern -buy a R35. that will pull the chicks and get you thrown in jail at the same time.
if you were doing a resto like I am then I could POSSIBLY see your point. at the moment I see a kid and dreams.
put up or shut up :)
THIS
/Thread.
Yes, the AWD system can be disabled. I wouldn't waste the time, effort and money doing such a costly conversion.
>Buy R34 GTR
>Disable the AWD system
>Profit!
Edited by JDM34
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
