hi guys
im wondering if any of you guys on here are plumbers. basically i want/need some work done and i cannot decide which way to go. below are some images that show my problem
as you can see my drains cannot seem to cope with 10 minutes of rainfall and whoever built my house did a shit job with landscaping. currenlty im looking into french drains but am not toooooo sure about it.
ill explain what i want done/are thinking about in much more detail when required.
thanks
adam
https://www.sau.com.au/forums/topic/391571-plumbers/
Qld??
Talk to god.
Just did my fathers drainage at his place in noosa last december (some holiday), same as you he had standing water and a lot of it. The solution was 5 pits stepped down to the road and a butt load of open gutter drains near the house with pipe work to tie all the shit together. Tools required 1 shovel, i pick, 1 level and some string. Took 3 days of off and on labour, probably 14-16hrs work by myself.
Edited by madbung
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6232460
yeh... im aethist so god probably would not want to hear from me lol
the problem with my place is that im below the street (JUST) so all of my stormwater and sewerage go back down the block (1,200m2) and from what ive gathered most of my underground pipes are under concrete. half of the problem is that the concrete is not leveled (imo) correctly to move the water away from the house
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6232664
By the looks of it you might be able to get the water out of there without cutting concrete. a few drain entrances next to the concrete with a pipe to the lower ground or something.
images 1 and 2... ive already done that. it does drain away eventually
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6232981
Gunna have to cut the slab and put couple of rain water outlets (generally bout 200mm round or square with a lil gal grate on top) in or get some arco drains (black poly grates bout 100mm wide come in 1m lengths) put in and hook them up into your existing stormwater lines. Do your gutters overflow in the rain? If so might be worth chucking an electric eel up the pipes or at least have them inspected with a camera to see whats going on on the inside mate.
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6233080
yeh i put in a drain here
which helped quite a bit but now its mainly around the front of the house (high ground) and the existing stormwater pipes have been concreted over (according to house plans)
i do have an electric eel like this
http://www.ebay.com.au/itm/20mm-100mm-Dia-Electric-Plumbing-Sewage-Drain-Pipe-Cleaner-Machine-S-/270906035928?pt=AU_Building_Materials&hash=item3f13420ed8
however the cutting head on it is not... good enough
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6233186
The camera option maybe worth while mate if the water still isn't getting away if its tree roots blocking the line try another head like the spiral looking head which will screw itself into the roots and hopefully you can drag them out
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6233224
had a similar problem and I am below street level. two runs of 5" pipe down both sides of the property with 4 square drains down each side of the house . it used to take 3-4 min of solid rain to flood the place. now its 30-40min of the same rain. I think I am 2-3 ft lower than the street.
took two of us about a week to do and about $500 in materials.
used a fair bit of sock and ag pipe as well. that and a decent layer of crushed rock about 6-10" under the top soil. the ditch is FULL of crushed rock as well. using that in itself drains that area quite well.
does that help?
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6233257
that does help chris thanks
but the problem with my place is that both sides of the house have quite a few large palm trees (that i want to get rid of anyway), both sides have a fence and a fair bit of concrete...
its not the work thats the problem but the lay of the land.
gonna have to pull some trees down first.
that last image, are those flex pipes tied in to your downpipes?
so who here is a tree lopper? :P
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6233405
yes.
the whole lot feeds into those pipes. the down pipes, ag pipe and yard drains.
the original 3" main pipe would not handle all of it. the 5" does.
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6233423
all of that black flex pipe and sock is crossed about every 15ft or so into a + fashion. it all terminates at the one point in the last photo.
the result is a fairly quick draining yard.
https://www.sau.com.au/forums/topic/391571-plumbers/#findComment-6234782
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
