Eoi High Performance Parts, Forged Rb26Dett, 2860-5 Turbo's, Oil Cooler, Apexi Power Fc, Front Mount Cooler, Oil Catch Can
looking at parting out a highly modified 1994 R32, above parts plus more, post here if your interested in a part and the price you're willing to offer, please no PM's as my internet is rather slow, car is still together, if i get enough intersted i will start stripping the car this weekend and will post detailed pics of parts as i remove them.
engine has EAGLE forged rods and CP forged pistons with receipts, 13'000 KM since complete overhaul including dyno sheet's with KM's at time of the engine build and recepits for the work (this includes the turbo's, engine internals, ECU, less then 5'000 on rims)
body panel's are strait, car is complete.
Edited by ttoks
a better written advertisement would move parts quicker mate. kinda hard to read
i'm a bogan that stuggles to turn the computor on, i'll pay ya a comission to sell em for me if you like.
also incase anyone might be intersted, i have an 08 YZ125 motorcrossbike for sale, off topic but never know.
Edited by ttoks
Pics of the oil catch tank showing location it is fitted under the bonnet and price please??
Info on cooler, core dimensions and brand would be good, and a pic verifying condition. Cheers
orry fella's, had all the pics and what not up and the power went out half way through uploading pics, going out for tea now so i will upload pics and details when i get back, cheer's.
okay part's currently off the car are as follow's all prices are negotiable, if your interested pm me an offer, location is traralgon VIC
to answer Q's, engine block has unknown k's, 13'000 since crack testing chemicly cleaned, reco head with new valves installed, eagle forged rod's and CP forged piston's, new water pump, oil changed every 3 months (around 1000-1200 km's) selling as long block only, no manifolds, no turbo's, not sure on price yet, hoping for around 7.5k or nearest offer.
oil catch bottle is mounted in front of battery.
cooler is a trust 100x300x600.
-oil catch can with hoses-$250 ono
-trust 100x300x600 intercooler, no damage, slight road dirt (easily cleaned)-$600 ONO
-driver's seat, slight tear (see pics)- $300 ONO
-passenger seat-$350 ONO
-rear seat, good condition no tear's or mark's-$350 ONO
-OEM radiator, good condition, no blockages, no damage-$200 ONO
-Yokohama ADVAN RS rims, gold, 18x10, 114.3 stud centers, 15mm offset, bridgstone 255 tires 50% perfect condition, like new-$3000 ONO
-fan belt idler pully and bracket-$50 ONO
-AC pump in good condition (AC working a treat before part out)-$150 ONO
-stainless exhaust, 2.5 inch from turbo's, 3 inch cat, 3.5 inch cat back, 4.5 inch tip, not to loud, in good condition, no leak's, no dent's, slight scratch marks-$450 ONO
oil catch can
intercooler
drivers seat
passenger seat
rear seat(backrest also for sale, good condition as well, still in car so no pics yet)
OEM radiator
yokohama ADVAN RS rims
AC pump
exhaust
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
