Hi
I have been a bit slack of late trying to sell all my gear as of other projects but here is the list of what's left, please remember people if i don't reply to you, it's because i will be at work out of town i usually do 4-5day stints so be patient please will get back to you as soon as i can. Also i will not be paying for any postage for anything so don't ask, just about all these parts are from japan and the postage for some of these parts were more the actual part itself. No time wasters genuine buyers only.
- Rays Gram Lights 57F Pro Titanium Lip Wheels with tires 18x10 +20 offset cost me over $4k selling for $2500
-Hankook RS-3 Tyres 285/35 R18 x2 New never used $600
- Carbon Look Mines Style Mirrors, Electric very good condition $300
- Carbon N1 holes for front bumper $100
- Nismo Side Clear indicators $60
- Nismo Carbon GTR Wing end caps $100
- Greddy E-01 Boost Controller - $300
- Bride Front Seat Rails Left and Right Type RX suit Ergo II, Brix II, Pros, Xax2 Seats - $300 for both.
- Superior Auto Creative Full Carbon Fibre Dash kit, includes Arm Rest Cover, Gear boot, Handbrake Boot and the whole dash Cost me $1500 selling for $800
- Sniper Carbon Fibre Kick Panels - $80
- Carbon Fibre Gauge Cluster Surround $100
- HKS Type R Intercooler 600x300x100 and piping $700
- Top Secret Style Stainless steel Catch with built in Squirter Bottle - $100
-Sard Air Bleeder Coolant Tank $50
- Billion Alloy Power Steering Tank $150
-Cusco Front and Rear Sway Bars $600
-Tein Monoflex Coilovers $1500
- Cusco Hicas Lock Bar $300
- Ikeya Formula Arms, consist of Front top arms and the 2 Rear Top arms $800
- Apexi Blow off valves x2 $150
- Koyo Alloy Radiator $300
- OS Giken Triple Plate clutch with push converter kit $2000
- R34 N1 Nur 2002 model Engine with Tomei 260x9.15mm Cams and Gears + Belt, Ross Harmonic Balancer, Hi octane Racing Sump Extension, Spool Head drain kit. done approx 25000kms from new $6500
- AP Racing 6pot Front Calipers, with 270x36mm 2 piece fully float rotors, (needs new rotors) $2000
- AP Racing 4pot Rear Calipers with 330x32mm 2 piece rotors, near new $2500
- Jun Style Carbon Fibre Bonnet with Aerolatch bonnet pins $700
https://www.sau.com.au/forums/topic/391803-r33-gtr-parts-clearout/
n1 carbon vents!!
sent to melb for 100???
wish u werent in qld like the sound of the bonnet! can u send me pics of it? may entice me to chase up a courier or something lol
SOLD PENDING PAYMENT
Also Sold pending payment, i will also put pics up of the other stuff that needs to be sold.
- Superior Auto Creative Full Carbon Fibre Dash kit, includes Arm Rest Cover, Gear boot, Handbrake Boot and the whole dash Cost me $1500 selling for $800<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">- Sniper Carbon Fibre Kick Panels - $80<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">- Carbon Fibre Gauge Cluster Surround $100
Also have a Works Bell Leather Steering wheel like new $200
OS Giken R3C Triple Plate Clutch
AP Racing 4 Pot Rears with 330mm Rotors
Ikeya Formula Top Front and Rear Arms
Apexi Bov's
AP Racing 6 Pot Fronts with 370mm Rotors
Mines Style Carbon Look Electric Mirrors
