hey guys im looking at getting a internal waste gate for my gt3076 as its a external gate model and im selling the rear housing and buyin a internal wastegate one
just wondering if anyone has seen or played with this internal wastegate seems to look pretty nice with the extra springs to go inside for desired boost levels
http://www.ebay.com.au/itm/Kinugawa-Adjustable-Turbo-Wastegate-Actuator-Garrett-GT3071R-A-R50-3-Spring-/270912634695?pt=AU_Car_Parts_Accessories&hash=item3f13a6bf47
just wondering how it would hold up boost as ive been told to get the 14psi garrett actuator but this one is a bit cheaper just wondering if it might work the same
Thanks guys
https://www.sau.com.au/forums/topic/391896-kinugawa-wastegate-actuator/
oh really are they the same as this one
any suggestions im goin internal gate for now just cause i bought a dump pipe and everything to suit off another member
i was looking for a actuator with a minimum of 14psi :) so hopefully theres no boost spike issues and im not sure if the rear housing im buying comes with the brackets and everything
I'm not turbo expert but I'm guessing Garret will give you the quality needed that 100 bucks could save thousands. Call gcg up I'm sure they will have one to suite
Edited by Bsa
yeah ill get the part number off them and get it from garrett direct cut out the middle man hahaha
hey just wondering i bought the mafia's dump pipe he had on his car with the gt3076 later down the track would it be able to weld the stock internal gate closed and weld a external to the manifold or is there no point as im only wanting to achieve 280-300 :) on bp98 thanks dude
ive seen a fair few results on here with the 56t .82 on 17-19psi internal gate make 280-300
the mafia made 315rwkw
i cbf getting a new dump pipe made up as im buying everything so its only a day job to put it all together
i was considering external gate but ive seen results pretty much the same using internal vs external with the .82 rear
when it comes to the .63 external for sure
I went in Mick_o's 33 with the .82 internal gate GTX3071 and can say the Garrett actuator does its job well.
The car was rapid and had really good boost recovery. I wouldnt think twice about going Garrett if its an option for you.
Blake I think the reported Kando issues are more around the housings than they are the actuators. Ive used a few of their actuators now and they work fine :thumbsup:
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
