i just want to clarify that my coupe has D2S D2R Xenon HID 8000K bulbs already, and what ever the factory high beams are. do i need any other bulbs to make this work?
Nope, you should be all good.
manc01 - I am quite you are NOT going to find any D2S HIDs in stock at any store in Adelaide (which is why I told you about buying them on Ebay on Monday).
And as per my PM, any H4 will do the job - you just need to decide on what quality you want. but be prepared ot be raped if you buy retail vs buying online.
  • Replies 478
D2S is different to DSR... D2S is projector, D2R is reflector, D2C is the only one that can be used for both
Nissan charges $240+GST EACH Bulb so buy from that ebay link i posted, the guy is so helpful if you want to know "what Phillips do i buy"
D2S 85122CX
D2S 85122CM
D2S 85122
D2S 85122+
D2S 85122WX
Read between the lines : "D2S is projector, D2R is reflector" - you need to figure out whether your glones are S or R. If they are S then that is what you want, if they are R they will still work, but the pattern will not be optimal for the new projector style lens.
Got mine also. They come in a very big box! I have only opened one but it looks like is has a bulb in the high beam???
Yes its a H1 bulb. you can get the 100% more vision one from philips if your not happy with that one.. only $43 from ebay.
YAY! Keith and I got ours today! Super rapped to fob off my RHS headlight! Thanks to everyone's input and patience and to Keith for organising it on my behalf! :)
Has someone installed them yet? I wonder what to do with the small box attached to the wires, tape it to the headlights when I install it? I know how to install the headlights, but I might need some advice assistance with the HID ballast and harness.
Id like to note thats just on parks and my flash make it look like my light is on. These were a direct plug and play for me, will put a hid kit on it eventually but for now the halogens are fine.
Anyone bought these? I think it's a just a simple halo ring add-on, looks good
http://www.ebay.com....=item53d9057c56
There is an extensive thread about these somewhere in the V35 section. Bit of a PITA job to fit including baking your lights to break the seals and open them, much stuffing around to fit the halos (including having to silicone them in = dodgy imho) and horror stories about the place on the net of people baking their lights too long and ruining them, not baking them long enough and damaging the seals when opening them, and the halos falling out of place or not being siliconed in perfectly straight and looking like shite. Not something I am game to do TBH - hence why I bought the aftermarket lights with all of the guesswork taken out. Plus it is fully/easily reversible to switch the lights back if you want later on.
Are you free Saturday morning/lunchtime to help/watch/drink while we fit the headlights to 5 x V35s Matt? Munro might pop around in his R35GTR for a look/help/drink too. It is getting some new toys fitted as we speak and will be making mid-400 awkws by the weekend :)
hey Damian, are your low beam bulbs D2S or D2R?
I haven't got mine fittet yet but my V35 is a series 1 with D2R bulbs and I'm a bit concern if they would fit ok in the projector lens of the new headlights.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
